ECM Flash Recall
Old Feb 25, 2014 | 11:06 PM
00Dog's Avatar
ECM Flash Recall
I made an appointment tomorrow at Austin's Covert Dodge so they could check my steering per the recall. They said on the phone that there is an older recall to reprogram the ECM. Is this a good thing to do? Will it affect my mileage or anything else? My truck runs perfectly and gets over 20mpg highway. I don't want it messed with. Advice please.
Old Feb 26, 2014 | 07:38 AM
Shorts's Avatar
Tell them in no uncertain terms "No" and "Do not flash the ECM".
Old Feb 26, 2014 | 11:06 AM
00Dog's Avatar
I like that. I actually had to cancel the appointment. On a separate note does anyone know how to look at the steering linkage to see if you fall under the recall? I'd rather avoid the dealer completely.
Old Feb 26, 2014 | 05:01 PM
EDR's Avatar
EDR
00Dog,
The simplest way to check is to look at your steering damper.
If it's connected to the tie rod tube by a bolt that goes through the tube, it's the older style linkage and is not being recalled.
If the damper is clamped to the side of the tie rod tube with a bracket, it's the newer (2008.5) style linkage that is being recalled.
Old Feb 26, 2014 | 05:58 PM
00Dog's Avatar
Thanks a lot. Going out to look.
Old Feb 26, 2014 | 08:14 PM
00Dog's Avatar
So I'm okay then right?
Old Feb 27, 2014 | 07:30 AM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
Mine is the same.
Old Feb 27, 2014 | 07:59 AM
J BODY's Avatar
so mr truckbouy.... perhaps in your worldly ways you could explain what he should probably look for to insure his steering linkage is in proper order.... I would, but I'm a "goon" with a wealth of knowledge, experience, and access to all the tools. Carry on....
Old Feb 27, 2014 | 08:08 AM
truckbouy2's Avatar
I stand corrected. My appologies.
Old Feb 27, 2014 | 11:49 AM
StealthDiesel's Avatar
__________________
2006 Quad Cab Short bed 4x4 48RE Traded for:
2007 Quad Cab Short bed 4x4 G56
For your 1st question about the dealer flashing your ECM, no one can answer this question accurately because you haven't provided enough information.
1. Is your truck stock? Do you have any interceptor type modules or is a programmer installed?
2. Does your 2007 truck have a 5.9L engine or a 6.7L engine? Both engines were available in model year 2007. You should update your signature to specify which engine you have.
Old Feb 27, 2014 | 12:05 PM
00Dog's Avatar
Sorry good points. It is a completely stock 5.9.
Old Feb 27, 2014 | 09:20 PM
EDR's Avatar
EDR
Regarding your steering linkage, you are okay and not part of the recall.
Old Feb 28, 2014 | 06:24 AM
Hvytrkmech's Avatar
Why the abrasive post? I agree you are a wealth of knowledge and a valued member. Just don't see anything posted or deleted to warrant your statement.
Old Feb 28, 2014 | 07:16 AM
truckbouy2's Avatar
"Why the abrasive post? I agree you are a wealth of knowledge and a valued member. Just don't see anything posted or deleted to warrant your statement."
I wrote a few general comments that weren't quite flattering for the dealer individuals. I totally agree with his wealth of knowedge statement but every dealer through the years I've had dealings with are lacking the wisdom to apply that knowledge. So I edited the comment lest Madhat has me doing pushups till the ants recognize me. Sorry, I've since mended my evil ways.
Old Feb 28, 2014 | 07:48 AM
Shorts's Avatar
I second. 00Dog, your steering linkage is not part of the recall. For future reference your truck has the old Ystyle steering linkage.
For further clarification I have included a side by side picture.
Left: Old Ystyle
Right: Upgraded Tstyle (this is the N62 recall linkage)
