DW help
Old Jun 27, 2008 | 04:17 PM
SjLingenfelter's Avatar
DW help
Ok i have read and read and read but cannot find a final answer to resolve the death wobble. Will someone please tell me what i need to do. I have a 2.5" lift with 315's up front and 35's in the back. I know the 315s are a big problem but i wanna have a final result to this.
thanks
sean
Old Jun 27, 2008 | 05:32 PM
XLR8R's Avatar
You'll probably get plenty of opinions & anecdotes...
basically, all components should be in spec for wear & adjustment - and all joints/moving parts should be as strong & firm as possible... i.e. some of the soft rubber OEM bushings need to go!
Here's my explanation of what actually happens - hope it helps:
https://www.dieseltruckresource.com/...7&postcount=32
Old Jun 27, 2008 | 06:08 PM
Tedonlin150's Avatar
There was an article in Diesel Power magazine where they installed a brace that strengthens the steering box. It was in there latest issue and the part costs like 300 bucks if i remember right.
Old Jun 27, 2008 | 06:48 PM
MTC's Avatar
MTC
Its the steering box stabilizer made by BD performance diesel. Its supposed to cure the DW.
Old Jun 27, 2008 | 07:05 PM
Tacsavage's Avatar
There are multiple companies making steering box stabilizers and it may help with the DW, but if you have other worn components, they need replaced as well. It can be everything from track bar bushings, tie rod ends, drag links, ball joints, worn or stock steering stabilizer with larger tires, even low tire pressure or any combination of the above. Sometimes it is difficult to find the exact cause, you may just have to get under the front and have some one work the wheel back and forth to see if you see any play in any of the components. Tac
Old Jun 27, 2008 | 08:26 PM
spooled05's Avatar
Look at the eccentrics on the lower arms if they both arnt in the same poss.than your axle is twisted wich causes a pos.to neg.pull on the front end wich weares out everything prematurley!
Old Jun 27, 2008 | 08:36 PM
i turned them both to positive caster after i did the lift.
Old Jun 28, 2008 | 11:11 AM
spooled05's Avatar
Sj were u in port a this past weekend?
Old Jun 28, 2008 | 01:12 PM
no i was at lake bryan here in college station bryan is there a twin of me down there?
Old Jun 28, 2008 | 01:21 PM
THURENfab.'s Avatar
Steering box brace will help, but not fix..
Your BFG tires are probably the biggest issue..
Rarely ever will you have the caster cams in the same spot, and them being not equal does not mean the axle is twisted..
Old Jun 28, 2008 | 04:12 PM
Raspy's Avatar
I agree with Thuren. The front axle is not "twisted" by having the adjusters in different positions. It is far stiffer than the rubber bushings that support it.
If you are getting DW a lot and you are driving on smooth roads when it happens, it is very likely the tires. An out of balance tire is the most likely cause. Big heavy tires must be accurately balanced on a quality spinning machine because even if they are statically balanced they can try to turn right left right left as they roll along and set up DW. A bent wheel is another problem that will set it up and also prevents accurate wheel balancing.
Bumps can set it off too and it becomes up to the damper to get it under control. In that case it's just the natural oscillating frequency of the wobbling mass. The more play or flex there is in the system, the harder it is to stop once it starts.
Old Jun 28, 2008 | 04:51 PM
spooled05's Avatar
Sj, yea almost identical
Old Jul 1, 2008 | 04:12 PM
Ok so i just left the dealer they have a part that is supose to fix the death wobble. Its a redesigned steering system. Has anyone heard of this before i go buy it?
Old Jul 1, 2008 | 10:05 PM
Ram Daddy's Avatar
Nope.
Is it something that is a recall / warranty type item , or something only offered to someone willing to pay for it?
Old Jul 2, 2008 | 12:34 AM
they said they found out alot of trucks were having this problem and they said its a fix to it. the guy at the dealer is a friend of mine so i know he wont try to kid me here.
