dual mass flywheel
Old Feb 27, 2008 | 10:32 AM
jbworm20's Avatar
dual mass flywheel
my dad has an 07 with a manual tranny and was wondering if the flywheel may be the problem bc is has a vibration at idle any help would be appreciated.
Old Feb 27, 2008 | 11:26 AM
Jeff in TD's Avatar
Mine has the dual mass flywheel and idles very smoothly...
Old Feb 27, 2008 | 02:00 PM
enafzige's Avatar
How many miles on the truck? The DMF's are pretty prone to failure.
A lot of people have traced vibrations to the front driveshaft as well.
Did the vibration just start, or has it always been like that?
--Eric
Old Feb 27, 2008 | 02:13 PM
jbworm20's Avatar
120k and the vibration just started
Old Feb 27, 2008 | 08:25 PM
Jfaulkner's Avatar
Muted User
If it's vibrating at idle I'd guess the flywheel also. I gave my stock DMF to a guy with an 06 because of the same problem. His had a lot of play between the 2 pieces after he removed it. If you do have a flywheel problem I strongly suggest that unless you get one free and are doing the labor yourself DO NOT buy another OEM clutch. They're very expensive and will fail again. I suggest calling a South Bend Clutch dealer and getting at least a solid flywheel replacement.
Old Feb 27, 2008 | 11:01 PM
scootertrash35's Avatar
he's lucky to make it 120k,ours went at 40k and 65k.both had a bad vibration at idle but would function ok.call SBC
Old Feb 28, 2008 | 12:03 AM
mj007's Avatar
There's a TSB out on the later 2005s (with the G56 & DMF) that seems like what your dad has got going on. It's TSB #18-015-05 REV. A
Old Feb 28, 2008 | 04:32 AM
darrenb's Avatar
i was told any vibration possibly due to clutch failure or deteriation is hazardous to main bearings.......per pete @ south bend clutch
Jona Gold
29
Jan 19, 2025 06:36 PM
laureena23
Jan 13, 2008 11:03 PM
Mr Traveler
Jul 13, 2006 06:31 PM
getblown5.9
Aug 17, 2005 12:30 PM
12PACK
Apr 13, 2005 08:25 PM
