Drivetrain or suspension?
Just had the front right U joint replaced at the dealer, it been about a week since I picked it up. I've noticed a vibration in the seat and steering wheel under throttle, not heavy throttle just normal driving, and it seems to go away at highway speeds. Any ideas??
I thought maybe lugnuts but they appear to be tight, or U joints in the driveshaft.
tell you the truth I think some of it is coming from the exhaust system... I don't know it just feels like it... another thing is I just did a trans. service and adjusted the bands and it seems to of helped the vibration... go figure ??????
I just had a similar problem, mine vibrated like heck upon deceleration. It didn't matter brake no brake clutch no clutch. I would jack up the rear and run it in gear if it's your u-joints or drive shaft you should see it. For me it was u-joints. I had to drop the drive shaft completely to be able to find the u-joint that was bad i replaced all three.-Shawn
I'm taking mine in to the dealer next week for a similar problem. I think it is either U-joints or a bent driveshaft. Either way, warranty is a good thing because I don't want to deal with it.
Well I had the truck into the dealer today. They aren't 100% sure what it is, but they are going to replace the rear driveshaft anyway because they also noticed it had over 1/4" of runout when spinning. And I'm glad they are covering it under warranty (I was worried because of the larger tires/lift blocks). But they didn't even mention it.
this also sounds like the launch shudder TSB. http://dodgeram.info/tsb/2004/03-003-04.htm
when I had it starting and stoping. I also thought it was u-joints. I tried a quick lowering of the driveshaft and it went away.
Originally Posted by 4x4not
Yeah, my problem with searching on here about most vibrations in the driveline came up with two-piece driveshafts. I have a SWB so mine is a one-piece.
good luck
mtnman006
24
Sep 8, 2009 03:14 PM
Commatoze
Jan 31, 2003 12:39 AM
latitud_rt
40
Jan 28, 2003 10:05 PM
northjeepster
Oct 15, 2002 01:11 PM
