Driveshaft support barring
Old Jun 22, 2018 | 02:06 PM
cabtruck's Avatar
I have a 06 quad cab 6 speed long bed can’t keep the driveshaft support barring it it. The barring comes out of the rubber isolater anyone have the same problem or any ideas
Old Jun 23, 2018 | 07:57 AM
FMB's Avatar
FMB
It sounds like your center support bearing has bit the dust. It should all be one piece with the bearing supported by the isolator. If they are separate, the rubber has torn. There are two different fixes for this issue. One is to replace the center support bearing (some put spacers in to lower it a bit, search for the thread). The second is to replace the two piece driveshaft with a one piece.
Back to morning brew . . .
Old Jun 23, 2018 | 08:12 AM
cabtruck's Avatar
has been lowered. I’ve replaced it with 4 new ones oreillys dealership and spicer.
I am a heavy truck mechanic so I know how to replace them.
I’m trying to figure out what is causing it to fail.
Drink your coffee I need someone with Mechanical knowledge
Old Jun 24, 2018 | 10:45 PM
StealthDiesel's Avatar
If your truck is a 4wd, the best solution is a 1 piece aluminum driveshaft. There are many places to get one.
If your truck is a 2wd, a 1 piece driveshaft is not an option.
You mention your truck is lowered.
If you altered the ride height and you are towing heavy, the driveshaft/U-joint angles have to be measured and perhaps a spacer added to the ctr support bearing bracket to change the angles.
Old Jun 24, 2018 | 11:28 PM
400HP's Avatar
I assume you mean you lowered the bearing on the mount.
The 1 pieces driveshaft isn't a cheap option and doesn't address why you are tearing the bearing out of the rubber. Very strange.
My best guess is a bad u-joint, balance issue, or a rough/seized slip yolk. Or maybe as previously mentioned your drive angles are out of whack
Good luck.
Old Jun 25, 2018 | 07:31 AM
I would pull the shaft out in one piece, purchase an OEM unit from chrysler, bring them both (the shaft and the new hanger bearing) to a local driveshaft company, and tell them the issue.
I know they've heard about this in the past, as "stuff gets around". Let them replace the U joints, carrier bearing and balance the whole unit.
I did that exact process, after years of changing my own U-joints. Been flawless since.
BTW I would DEMAND Spicer non greasable units. That's what I went with and again, been perfect since. I really think that balancing the unit is key.
Old Jun 25, 2018 | 02:31 PM
cabtruck's Avatar
Thanks for the reply’s I was told by my local drive shaft shop that it was to long get a single shaft. A friend of mine has a 07 3500 with a factory one peace shaft made some calls today think I found one that will definitely be the cure
cLAYH
Sep 16, 2010 07:39 PM
demolition_x
Jan 4, 2007 07:35 PM
Begle1
Aug 5, 2006 10:49 PM
mr T
Jan 17, 2006 12:10 PM
