Drive shaft angle ???
Old Jul 24, 2008 | 03:27 PM
tritont's Avatar
I was hoping someone that has a mega cab might also have a " angleometer" if that's what it's called.
I need to know the angle of the drive shaft between the transfer case and carrier bearing.
I called the dealer but, they don't have that info
Old Jul 24, 2008 | 09:15 PM
mrblond's Avatar
how about a protractor?
So how big a lift do you have or why the worry about DS angle?
Old Jul 24, 2008 | 09:26 PM
tritont's Avatar
that would work but, I need someone to do it. The reason I need this info is, I installed a custom adjustable carrier bearing bracket. I didn't check the angle before I took it apart. I can make the two shaft straight as an arrow but, the shaft is question has to have some angle to it. I just need to know the angle to I can adjust accordingly
Old Jul 24, 2008 | 10:17 PM
CRXsi's Avatar
I'm not sure if it helps but check out this link for ujoint angles:
http://www.drivetrain.com/driveline_angle_problem.html
KATOOM
24
Jan 13, 2005 05:49 PM
joel
Oct 1, 2004 04:18 PM
AaronT
Jul 26, 2004 08:32 PM
ppsi
16
Jan 5, 2004 05:42 PM
dsljunkie
30
Oct 16, 2003 06:16 AM
