Double Deep pan question
Old Mar 25, 2009 | 02:17 PM
GT451's Avatar
I have recently purchased a Mag Hytec Double Deep trans pan for my truck from Geno's and it came with a filter spacer. Does this spacer not require a seal or gasket to seal it to the valve body? I didn't see one in the box.
Old Mar 25, 2009 | 02:21 PM
John Faughn's Avatar
You will need an extra seal , one permanent between the spacer & VB , then one between filter & spacer , after that , each filter change you just need the one at filter .
Old Mar 25, 2009 | 05:21 PM
GT451's Avatar
Thank you, John. Do you maybe know where I can obtain said seal?
Old Mar 26, 2009 | 09:34 AM
When you go to change out the pan , get a new filter kit [ comes with a gasket ] , then pull out of box to make sure that when you tell the counter guy that he gets you another just like that , I haven't have that yr. apart so not sure , but in the past they are gaskets , not seals .
So most any parts house , but I try to avoid the do it your self places , Napa is a good all round source .
Old Mar 26, 2009 | 10:45 AM
GT451's Avatar
Sounds good. Yeah, I like NAPA too.
Thanks for your help.
The_Head
Sep 19, 2010 03:10 AM
EverydayDiesel
Nov 11, 2007 09:33 AM
KRB
Jan 28, 2007 04:54 AM
MrKen
Nov 23, 2006 03:19 PM
BigBlue
Sep 30, 2005 08:27 AM
