Dodge Durability??
170k
i'm on my 3rd transmission. suncoast this time
1 turbo
front and rea pinion seals
all 4 door locks
2 fan motors
1 blend door
2 lift pumps
1 injector line
1 ac compressor
1 ac hose
1 computer prob and has to be towed in
1 rear u joint
both batteries by 65k miles
fuel rain censor
abs censor
things wrong now
front end wore out
ac blowing 70 @ the coolest
i have to take a reader with me to reset codes because i get some every week and it wont hardly run
1 turbo
all 4 door locks
2 fan motors
1 blend door
2 lift pumps
1 injector line
1 ac compressor
1 ac hose
1 rear u joint
fuel rain censor
abs censor
things wrong now
front end wore out
Here is the list of maintenance I have done on my truck with 472750 miles on it.
DATE MILES SERVICE
6/18/2007 7038 Oil Change
7/2/2007 15848 Oil Change
7/5/2007 16080 Fuel and Air Filter
7/16/2007 21770 Oil Change
8/3/2007 29633 Oil Change
8/25/2007 39839 Oil Change
8/25/2007 39839 Fuel and Air Filter
9/17/2007 49358 Oil Change
9/18/2007 49370 6 new tires
10/5/2007 55774 Oil Change
10/19/2007 61776 Oil Change
11/10/2007 74145 Fuel and Air Filter
11/12/2007 74185 Oil Change
11/13/2007 74258 Tranny sensor service, fluid change
12/4/2007 82344 Oil Change
12/19/2007 90118 Oil Change
12/21/2007 90174 Rear Differential Fluid Change
1/7/2008 99866 Oil Change
1/21/2008 106697 Oil Change
1/27/2008 109119 Fuel and Air Filter
2/7/2008 115775 Oil Change
2/8/2008 115807 2 new tires for front and old ones to the rear
2/25/2008 121198 Tranny Fluid Change
2/25/2008 121198 Front Pinion Seal
2/25/2008 121198 Front Differential Fluid Change
2/25/2008 121198 Rear Differential Fluid Change
2/26/2008 121220 Oil Change
2/26/2008 121231 Fuel and Air Filter
3/6/2008 127417 Oil Change
3/27/2008 136914 Oil Change
3/27/2008 136920 Fuel and Air Filter
3/31/2008 137037 2 new front tires and old ones to back
4/11/2008 142370 Fuel and Air Filter
4/18/2008 145448 Rear U Joint
4/28/2008 147875 Tranny Replacement
5/1/2008 149165 Fuel and Air Filter
5/2/2008 149179 Ball Joints and Axle U Joints
5/15/2008 155679 Tranny Fluid Change
5/15/2008 155679 Rear Differential Fluid Change
5/16/2008 155693 Fuel and Air Filter
5/16/2008 155695 Fuel and Air Filter
5/17/2009 155727 4 Rear Tires
5/30/2008 162063 Fuel and Air Filter
6/13/2008 170373 Fuel and Air Filter
6/13/2009 170378 Fuel and Air Filter
7/2/2008 180800 Oil Change
7/18/2008 180825 Fuel and Air Filter
8/7/2008 190460 Oil Change
8/25/2008 195601 Oil Change
9/5/2008 200568 Oil Change
9/5/2008 200578 Tranny Fluid Change
9/5/2008 200578 Rear Differential Fluid Change
9/17/2008 200847 Fuel and Air Filter
10/2/2008 210002 Oil Change
10/6/2008 210117 2 links, front torsion bar
10/8/2008 210143 2 front shocks
10/9/2008 210198 Front Pinion Seal
10/14/2008 212000 Rear U Joint
12/29/2008 214202 Oil Change
5/6/2009 248408 Oil Change
5/9/2009 248463 Fuel and Air Filter
5/22/2009 256951 Oil Change
6/5/2009 263009 Oil Change
6/6/2009 263086 Fuel and Air Filter
6/12/2009 266456 Idle Pulley
6/17/2009 267528 Tension Pulley
6/17/2009 267528 New Belt
6/26/2009 271931 Oil Change
6/27/2009 271955 2 Front Tires
7/15/2009 281703 Oil Change
7/16/2009 281775 Left Axle U-Joint
7/19/2009 281790 Fuel and Air Filter
7/21/2009 282420 Right Axle U Joint
7/29/2009 287526 Oil Change
8/13/2009 293903 A/C Compressor and Repair
8/13/2009 293903 Tranny Fluid Change
8/17/2009 294357 Oil Change
8/28/2009 302777 Oil Change
9/5/2009 306188 2 New Batteries
9/15/2009 310579 4 Rear Tires
9/16/2009 310590 Anti Freeze change
9/17/2009 310651 Oil Change
9/17/2009 310680 Fuel and Air Filter
9/18/2009 310680 Blower Motor
10/2/2009 316589 Oil Change
10/15/2009 323840 Oil Change
10/20/2009 324640 Carrier Bearing, searching for a noise, but not found and old still good
10/20/2009 324640 Rt Front Bearing replacement, old still good
11/3/2009 332743 Oil Change
11/4/2009 332758 Transfer Case Fluid Replacement
11/20/2009 337057 Fuel and Air Filter
11/12/2009 337057 Rear U Joint
11/25/2009 341465 Oil Change
12/16/2009 351621 Oil Change
12/31/2009 356866 Oil Change
1/14/2010 364950 Oil Change
1/14/2010 364950 Fuel and Air Filter
2/10/2010 378278 Tranny Fluid Change
2/10/2010 378278 Front Differential Fluid Change
2/10/2010 378278 Injector Flush service with fuel filter change
2/11/2010 378310 4 Rear Tires
2/11/2010 378317 Oil Change
2/11/2010 378317 Air Filter
2/25/2010 386172 Oil Change
3/12/2010 394466 Oil Change
3/12/2010 394477 Tension Pulley
3/27/2010 403492 Oil Change
3/27/2010 403492 Fuel and Air Filter
4/1/2010 403659 6 new Injectors
4/2/2010 403740 Fronts to Rear outside and rears to front
4/12/2010 408630 Tranny Hose to Block Replacement
4/17/2010 412450 Oil Change
5/9/2010 423884 Oil Change
5/9/2010 423907 Fuel and Air Filter
5/10/2010 425130 Rear End Study
5/18/2010 429188 Rear U Joint
5/27/2010 433839 Oil Change
5/28/2010 433839 Driver Wheel Bearing
5/28/2010 433839 Front Rotors,Calipers, Pads
5/28/2010 433839 Left Axle U-Joint
6/16/2010 442000 Oil Change
6/16/2010 442093 2 new front tires and old ones to back
6/17/2010 442184 Fuel and Air Filter
6/29/2010 450500 Oil Change
6/29/2010 450500 Rotate Front Tires
7/6/2010 450947 Check Axle U Joint on Passenger side
7/14/2010 454577 Tranny Fluid Change
7/16/2010 454700 Oil Change
7/29/2010 462246 Oil Change
7/31/2010 462342 Fuel and Air Filter
8/6/2010 465848 Wiper motor and assembly for the wipers to operate both sides
8/6/2010 465848 Idle Pulley
8/6/2010 465848 New Belt
8/6/2010 465848 Tranny Fluid Change
8/6/2010 465848 Transfer Case Fluid Replacement
8/6/2010 465848 Front Differential Fluid Change
8/9/2010 465935 2 front tires and old tires to rear inside and 2 new outside tires
8/19/2010 472750 Oil Change
DATE MILES SERVICE
im at 554,000 here is what i have done to mine so far..
014k F.A.S.S.
127k Plantdrive Veggie Kit w/extra mods
128k alternator
188k starter
200k both batterys
227k Ball Joints both sides upper/lower
312k New Clutch
341k U-joints w/seals
390k Rear Diff rebuild
402k Rear Main Seal
481k New Clutch
502k Turbo Rebuild
014k F.A.S.S.
128k alternator
188k starter
200k both batterys
312k New Clutch
402k Rear Main Seal
481k New Clutch
502k Turbo Rebuild
Roadmedic, did you ever find that noise you were looking for when you changed out the carrier bearing?
By the way, bought mine last spring with 208K. My only major expense so far has been ball joint replacement and tires. Just finished a 5K mile trip with no problems.
Fellow CTD owners - a lot of the population buy these trucks (and the other brands) when really they should have walked down to the Ferrari dealer but probably turned in the wrong direction. What I am saying is I pull 7 tons with a basically stock 07 5.9 6 speed. I don't need to go down the highway at 100mph - 60 is fine, my fuel economy is good empty and towing. Don't slam the brakes on, dont rev the pi$$ out of a diesel that was designed originally to pull 2500. Don't try and get around a street corner in a microsecond - take your time, it's a truck! Take off steady, slow down early, cool that turbo down, change the oil often, you don't have to go up the hill in 6th gear just to get bragging rights. You may find that your truck will last a long time and really - a lot of extra maintenance is due to your driving habits. Otherwise - go buy the Ferrari.
i'm at 175000 miles.
rear drive shaft u joints twice
front drive shaft u joints once
brakes a couple times in the front once in the rear.
lift pump once under warranty
I pulled heavy loads for two years thats why the u joints and brakes..
No, it is still there. It seems to be wind noise through the Cowl and maybe to the blower. It comes and goes based on the wind directions and speed.
170k
1 turbo
all 4 door locks
2 fan motors
1 blend door
2 lift pumps
1 injector line
1 ac compressor
1 ac hose
1 rear u joint
fuel rain censor
abs censor
things wrong now
front end wore out
1 turbo
all 4 door locks
2 fan motors
1 blend door
2 lift pumps
1 injector line
1 ac compressor
1 ac hose
1 rear u joint
fuel rain censor
abs censor
things wrong now
front end wore out
towed home today----2nd airdog150 dead.......just makes noises and doesnt pump... p0148 code.. just to be honest i wish this thing would burn.
signature600
19
Jun 8, 2006 07:14 AM
codystroh
16
Jun 11, 2004 06:04 AM
Scubasteve
Oct 4, 2003 08:11 AM
