Dodge @ Cummins techs help
Old Feb 1, 2006 | 07:41 AM
Tree DR's Avatar
What can you monitor with you diagnostic tool/computer? I would assume everything, can you adjust things with your computer? Is there any way I could buy one?
Old Feb 1, 2006 | 01:19 PM
bigblock2stroke's Avatar
You can monitor all the same things that an aftermarket "monitor" can (or OBDII messages).
You can't adjust things, you can only reprogram and with the DRB you can't modify the engine software. You can enable/disable algorithms, but you can't change fueling/timing/boost etc.
No, you can't buy it.
Old Feb 1, 2006 | 02:56 PM
CRXsi's Avatar
You can buy the DRBIII but it isn't cheap...
http://cgi.ebay.com/ebaymotors/Chrys...QQcmdZViewItem
or
Old Feb 1, 2006 | 06:39 PM
Originally Posted by CRXsi
$6k????
I smell a rat.
Old Feb 1, 2006 | 06:45 PM
CRXsi's Avatar
Maybe...but it's brand new with all software updates for 3 full years as opposed to used. I know the Scan tool for the dealership I work for is in the neighbourhood of $10,000 Canadian! Ouch.
Old Feb 1, 2006 | 07:12 PM
Tree DR's Avatar
Monitor but not adjust
I need to adjust things not just monitor them. So only dealers can have that softwear. How are the after maket HP people adjusting things? Just guessing or are they doing it on the go? Someone was talking about their HP box in stock mode being from Brazil or something. Marco on the TDR must of figured the programs out on his own. They were talking about a timing box the other day on here what happened to it?
Old Feb 11, 2006 | 08:42 AM
CRXsi's Avatar
I just found that if you order the DRBIII right from Daimler-Chrysler it is $6053.75
The attached link is for the order form and pricing:
https://techauthority.gltghosting.co.../ScanToolFlyer
Old Feb 11, 2006 | 10:52 PM
Tree DR's Avatar
Drb
Isn't that still just to monitor and reset codes? You can't change anything with it can you, well like timing or fuel?
Old Feb 12, 2006 | 06:11 AM
Hounddog's Avatar
Nothing can be changed other then door locks or seat belt chimes etc.
Old Feb 12, 2006 | 09:32 PM
Tree DR's Avatar
Thanks for the info.
I appreciate the info. That's what I figured only the manufacture can do the changing on the go.
I think I've found a solution though. It can be done and hopefully I'll have it up and going soon.
Tree DR
GMScott
Mar 9, 2009 09:31 PM
coalburner400
Mar 14, 2008 06:52 AM
rjm022
Oct 31, 2007 09:13 PM
Whalecap
16
Sep 3, 2006 10:24 PM
LCH
23
Sep 5, 2005 10:20 PM
