Do u-joints make noise when going bad?
Old Aug 12, 2008 | 03:41 PM
Ram Daddy's Avatar
Question Do u-joints make noise when going bad?
My truck has been making a VERY intermitent (sp?) noise that appers to come from under the truck at highway speeds (65-up).
The first time it did it I was on the highway for less than 10 minutes , it sounded kind of like there was something banging around under the truck. I turned off the radio , put the tranny in N and revved the engine....it was not engine related , as it didn`t speed up with the RPMs , but did go away after I got under 50mph.
I drove to my mech. friends place , and couldn`t get it to do it again (isn`t that ALWAYS the way).
Fast forward 3 weeks later , to this past weekend....I took a trip to Gainesville (about 3 1/2 hrs) and had the cruise set at 67 the entire way with NO noises. Drove another 200 miles while I was there , again NO problems.
On the way home we were stopping in Ocala , running 75 or so,(1 hr drive from where we were), and just about the time we were going to get off the interstate , the noise came back...scared the heck out of the kids. I really wish I had a better way of explaining the noise to you guys , the kids thought it sounded like we were going over a set of railroad tracks...I though it sounded like the driveshaft had come loose and was banging around.
Once we got off the highway , it went away. We went to the waterpark for a few hours , and continued the drive home...this time at 60 mph....(man were we ever getting blown off the road by everone)and had no more noises. About 25 minutes from home I got back up to 70-80 to see if it would do it again closer to home , but no luck.
The lift has been on the truck for several years with no problems (it only has a 3in. block in the rear) , but I`m just wondering if the u-joints are getting ready to go. Everything under the truck seems tight.
Sorry for the long post , but I`m at a loss as to what it could be , as it doesn`t do it all the time.
Any ideas?
Old Aug 12, 2008 | 03:57 PM
John Faughn's Avatar
Get the truck in the air with jack stands , get a large screw driver to pry with , as you turn the front wheels by hand , stick the screw driver in on each of the 4 joint cups & try to pry a little , should not be lose , also watch closely for brown rust stains around seals to bearing cups .
Then go to ft. drive shaft , use pry bar to turn drive shaft & wiggle yokes at u-joints , while watching & fealing for looseness , then back the r. drive shaft .
As long as its in the air , grab the top & bottom of ft. wheel and alternately push & pull on the top & bottom , should not be lose or clunk - clunk .
Then gab the wheel front & rear & wiggle , should not find lose , if so have some one go to each of the steering parts , while someone is wiggling the wheel , to look for lose parts .
Then to the rear wheels , wiggle to see if bearings are lose .
Old Aug 12, 2008 | 08:43 PM
Ram Daddy's Avatar
I`ll check those things out...thanks.
Would the u-joints (or anything else really) make a noise ALL of the time , or could it be just sometimes?
Old Aug 12, 2008 | 09:51 PM
megacabdad's Avatar
Sounds more like a wheel bearing to me. I've seen bearings that had no play in them what so ever, and made no noise, except for at certain speeds. U-joints will also make noise though, so like John said, make sure they are tight and no rust around them.
Good luck. Noises are fun to find.
Old Aug 13, 2008 | 02:13 PM
Ram Daddy's Avatar
Thanks guys...I`ll have them checked too.
The worst part of the whole thing is being scared to drive the truck too far away from home and getting standed (again!). Suckss to have a 40K dollar truck you can`t trust.
fatpete
15
Nov 28, 2010 10:13 PM
wrenchmaster
May 24, 2010 11:01 AM
jiggerman78
May 2, 2009 06:38 AM
lanwangeek
24
Apr 30, 2008 10:23 AM
FirstDodge
Feb 26, 2007 06:05 PM
