Diff Gaskets?
Old Mar 30, 2009 | 11:20 AM
Bowser50's Avatar
Diff Gaskets?
I am planning on draining and replacing my diff and trans(manual) oils. with the diffs do I need to buy gaskets from a parts store or can I use Red RTV?
Old Mar 30, 2009 | 11:40 AM
MikeyB's Avatar
The gaskets on the diffs are reusable. No need for RTV.
MikeyB
Old Mar 31, 2009 | 02:13 AM
choppers555's Avatar
MikeyB is right they are reusable but if yours is bad geno's garage has them online. But you can also use Gasket sealer
Old Mar 31, 2009 | 11:17 AM
bradler's Avatar
hey just a tip clean around the gasket (especially the top) very well before you pull the cover so you don't get any dust/sand in the diff! I usually go over it with a wire brush, then spray it off w/ brakes part cleaner then finish it off with the air gun. don't ask me how i know how bad it sucks to knock sand into the carrier....
oh yah and be careful not to over tighten cover bolts when putting it back together because they are prone to snapping off, i think torque spec on those it only 27ft/lbs.
Old Mar 31, 2009 | 12:18 PM
Bowser50's Avatar
cool thanks for the info appreciate it all.
Old Mar 31, 2009 | 01:36 PM
SOhappy's Avatar
Not steal your thread, but...
I'm going to be doing my second drain and fill on the diffs and am looking for advice on inexpensive (bulk) synthetic gear oil. As an example, even Supertech is $11/qt, so that's like $80 or so for the change. Is there a less expensive source where you can buy by the gallon instead?
(please spare me the "you get what you pay for" lecture, what I really want is where can I buy gear oil cheaper in-bulk? I've checked the auto parts stores and haven't come up with anything)
Old Mar 31, 2009 | 02:13 PM
Stock 99 CTD's Avatar
Bowser50,
I have changed my Diff's twice. Careful when removing covers and the gaskets are good to go. I will probably change the gaskets on the third go around just in case they are starting to crack or weather
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
shaft
13
Jan 29, 2004 07:37 AM
srowen
Jun 27, 2003 06:44 PM
mymaur
Dec 23, 2002 08:28 AM
