Diagnose this defective Piston with photos
Old Jun 4, 2008 | 12:45 AM
joesixpack's Avatar
The top ring was broke, seen some egts alright, but still, this piston was a wimp....and has fishy crack. You can see this crack that kind of follows a 45 degree to the steel ring land. The other 5 look like new.
Clearance, Clearance, Clearance
Old Jun 4, 2008 | 01:11 AM
crash969's Avatar
head gasket? cant see the position of the pin? but the stamp in still their
Old Jun 4, 2008 | 07:32 AM
Fisherguy's Avatar
What were you running when that happened?
Old Jun 4, 2008 | 09:49 AM
joesixpack's Avatar
Was running the Tst when the initial damage, or failure occured, But seemed harmless, a bit of blow-by, I knew one cylinder had some issues. Wanted to try a smarty and on the first day with some timing finished that wimp off.
Sure liked the Smarty the bit I ran it, liked it more than the Tst, and way cooler egts.
Old Jun 4, 2008 | 11:48 AM
matego's Avatar
madhat's monkey boy...
Throw that runt of the litter in the scrap bin. Natural selection, only the strong survive! It has STD's anyway, I could see it.
Which hole was it? The rearmost cylinders see the highest EGT's and that piston was in meltdown. The damage was on the exhaust side so I am going with too high EGT with a Friday piston. Good thing you caught it before it got worse. You know the drill, check the valves while the head is out and reassemble.
madbull
Feb 5, 2010 08:42 PM
mcmike
Apr 29, 2008 04:35 PM
GooseHunter88
17
Aug 10, 2007 08:05 PM
george7941
Mar 12, 2006 09:47 PM
