Dealer says No Warranty on Balljoints.
Called the Dodge dealership today to see if ball joints are covered under warranty. The ball joints are going bad at 45,000 miles. Dealer says not covered under warranty. What do you guys recommend for replacements? Are there ball joints out there that would hold up any better than the stock ones? Anything I should know about replacing them?
that is one way, but that assembly is so heavy, I put a pry bar of some sort under the jacked up wheel, and lift up on it. If it moves up when you lift, it is bad, there is a tolerance for movement in the ball joints, but I do not remember what it is..
and wearing out bearings and ball joints more often than normal is a price you're gonna pay.
Tell your dealer the guys at the DTR said to get with the program.
