Dead throttle in gear at stop
Old Apr 10, 2020 | 09:04 AM
Dodge 2005's Avatar
2005 Dodge ram 3500 idles & rev in park but peddle is dead in gear when it starts rolling peddle comes back works fine idle does increase when in gear any ideas only 58000 miles on truck I have changed tourqe converter clutch solenoid tps seams to be working transmission shifts fine anyone ever had this happen & what was the fix
Old Apr 10, 2020 | 10:19 AM
nonrev's Avatar
Super Moderator
10 Year Member
Welcome to the forum, that said you might want to post this in the 3rd gen section. On these trucks if you have a dead pedal either your cable broke or the fuel filter is plugged
Maybe a mod will move it for you
Old Apr 10, 2020 | 07:18 PM
Dodge 2005's Avatar
Its electric throttle work's fine without a load rev up & idles in all gears if transfer case is in neutral work's fine after truck is moving shifts fine just dead peddle at stop cable is ok TPS has proper voltage
Old Apr 11, 2020 | 08:23 AM
AZ2A's Avatar
what Nonrev was referring to is that 1st gen trucks (the forum your posted in) do not have an electronic throttle we have a cable...
Zac Caruso
Aug 10, 2014 02:40 PM
cwebb710
Feb 28, 2012 12:55 PM
daddy mopar
Sep 2, 2009 07:57 AM
stroker4501
Oct 1, 2007 10:35 AM
