Dead Again, ???
Old Feb 8, 2008 | 03:34 PM
kawi45's Avatar
Dead Again, ???
After being on the road all day truck was perfect, pulled in to a subway sandwich shop, and truck will not restart. this is the fourth time that i have shutdown and it will not restart. well the other three times it started after messing with the key back and forth and it finally engages the starter and starts. this time not so lucky. After flat bedding it home 40 miles i threw scan tool on it and up came 5 codes. any help with this codes would be greatly appreciated.
1. p2509
2. p0463
3. u1403
4. u1421
5. p0513
Old Feb 8, 2008 | 04:08 PM
Sprinter17's Avatar
Muted User
Usually when a vehicle stalls,or half starts ,or whatever,it will throw a list of codes, but your going to have just one bad part. Just have to find the real code,or bad part.
Old Feb 8, 2008 | 04:34 PM
donhov's Avatar
I have a code defination book and found the following:
1. p2509--nothing
2. p0463--fuel level sensor A circuit high input
3. u1403-- Dash cone?
4. u1421--Dash code??
5. p0513--Immobilizer incorrect
I think that the U codes are from the dash check. As far as what the others mean hopefully someone else can help. I could not find anything for the P2509 code as most end at P0999 that I can find.
Hopefully this can help a little.
Don
Old Feb 8, 2008 | 04:46 PM
kawi45's Avatar
thanks abunch guys!!!
Mlucas's Avatar
just a thought-could it be your keyfob is junk? these new keys are needed to start the truck...& if the battery is a dud, then maybe try with your spares???
Old Feb 8, 2008 | 04:51 PM
stickler's Avatar
I thought the battery was only for the keyless entry transmitter portion. The regular transponder keys without the keyless entry don't have a battery, or at least not a replaceable one.
kawi45's Avatar
I just got off the phone with my remote start guy and he says thats what it might be, he sees gym tags, cvs discount tags on peoples keys all the time screwing these up
Old Feb 8, 2008 | 05:18 PM
kawi45's Avatar
from what i understand the cystal in the key get screwed up, nothing to to do with the battery
Old Feb 11, 2008 | 09:15 AM
Mlucas's Avatar
have you tried your spare key?
Old Feb 11, 2008 | 09:22 AM
TurboTed's Avatar
Originally Posted by Mlucas
have you tried your space key?
It's the one you use when you go to Mars!
Old Feb 11, 2008 | 09:29 AM
Mlucas's Avatar
oops-EDITED
Old Feb 11, 2008 | 09:39 AM
TurboTed's Avatar
oops-EDITED
"Whew!!" (My next question was going to be whether or not you use bio-diesel!)LOL!!
Old Feb 11, 2008 | 11:00 AM
kawi45's Avatar
Spare key did not work, cleaded the codes with my pedator and it started right up???? no codes have come back thanks
again
Old Dec 9, 2010 | 12:21 PM
vang1111's Avatar
Similar issue with my 2007 MegaCab 5.9L. Experienced it ocasionally, but it would start after ensuring the shifter was in park or neutral. Once I also had to flatbed it. Got to the garage and it started right up. Cleared the codes and have been doing daily checks since. On hard rights and bumpy roads I'm getting my security light flashing. After that I'll check the codes and I'm getting P0513, Invalid SKIM Key consitently. clear the code and continue to roll. So what modual is related to the P0513, Wireless Control Module?
Old Dec 9, 2010 | 01:25 PM
SpeedyWS6's Avatar
U codes are usually caused by loss of communication on the can bus data line. (the computers on the truck are not able to talk to one or more computer in the can bus data line)
I'm going to bet that the SKIM is not talking to the PCM and you are in theft mode because of that.
Get ready for a trip to the dealer as star scan is the only thing that will be able to communicate with the proper modules to diagnose the problem.
Steven K
Jun 4, 2009 10:32 AM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
b84u
Feb 20, 2006 01:04 PM
billygoat02
Dec 30, 2005 09:19 AM
