DC and the CP3
Old Jan 26, 2007 | 06:03 AM
  #31
rich2500's Avatar
[IMG][/IMG]
couple photos for those that never seen the inside of a cp3
Old Jan 26, 2007 | 06:05 AM
  #32
rich2500's Avatar
[IMG][/IMG]
Old Jan 26, 2007 | 06:06 AM
  #33
rich2500's Avatar
[IMG][/IMG]
Old Jan 26, 2007 | 06:41 AM
  #34
sawboywv1's Avatar
Thanks, Thats Cool
Old Jan 27, 2007 | 11:33 AM
  #35
Polish Rocket's Avatar
Rich2500 when you swapped out the o-rings to the larger 1mm o-ring did you replace all of them? Ive never spit the pump before so it is hard to visualize what o-ring got replaced. Did you use off the shelf, universal o-rings say from a auto parts store or are they from a diesel injection pump supply house/shop? My concern would be that you want to make sure the o-ring material is compatable with the environment of the CP3. Apparently whatever o-ring material you have used is sufficient.
Thanks for the info!!
Old Jan 27, 2007 | 11:56 AM
  #36
sawboywv1's Avatar
OH NO, He spec'd out the correct stuff!!!
Old Jan 27, 2007 | 12:15 PM
  #37
rich2500's Avatar
sawboy is correct,I done alot of searching till I found what I needed,then I took it one step further and went the 1mm thicker for a better seal,there are 7 o-rings and two shaft seals that need to be replaced to stop the leak,there is also another seal in the pump but it's not necessary to replace it because it's just a dust and dirt seal and should not be worn at all.
Old Jan 27, 2007 | 07:00 PM
  #38
53 willys's Avatar
Originally Posted by rich2500
rich2500,
I am trying to figure out if this is a shot looking up from the ground or from the top??
I am trying to figure out where the CP3's leak at??
I have been searching the forums for the last 30 min's trying to find a pic of the leak.... I thought there was one floating around here but I cant find it.
I am VERY interested in the how to tech write-up on how to rebuild a CP3 to not leak.
Thanks
Mark
Old Jan 27, 2007 | 08:37 PM
  #39
rich2500's Avatar
in that photo the pump was actually laying on the bench,but when it's on the truck it's down on the bottom.going to the shop tommorrow to do the write up.
Old Jan 27, 2007 | 08:49 PM
  #40
Ramcam's Avatar
Ok what kind of performance issues can you see with a faulty pump.I am getting the odd wiff of diesel and i dont know if its my imagination or not but the truck feels a bit sluggish occasionally.I know it could be other things but is there a slight performance issue?
Old Jan 27, 2007 | 10:04 PM
  #41
ROOSTER108BM's Avatar
rich2500, So where does it leak from,the freeze plug looking thing or the bolt hole? thanks,Rooster
Old Jan 28, 2007 | 05:13 AM
  #42
rich2500's Avatar
some have reported that their truck felt a little bit better performance wise after the leak was taken care of,others say they don,t feel a difference,I personally felt a difference after fixing my leak,I think it's a matter of how bad the leak is.
Old Jan 28, 2007 | 05:17 AM
  #43
rich2500's Avatar
actually rooster neither,the o-rings internally leak and the fuel comes out between the two halves of the pump,it just so happens that where that bolt hole and plug are is where the fuel drips from,(when the pump is bolted on the truck that is the lowest point of the pump)
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
