dash board brake light stays on
Old Aug 29, 2013 | 03:57 PM
mtb1982's Avatar
Ok, just replaced my p/s pump and flushed the old brake fluid out and replaced with DOT 4 on my 2003 dodge 2500. I've only driven it about 150 miles and the dash-board brake light; the one that lights up when the parking brake is on; lit up and stays on. The ABS light didn't come on when it happened and I didn't hear any warning chimes. Master cylinder level is full and p/s pump is full, and when I installed the pump I followed the bleeding instructions posted in the forum site. Also, the brake pedal has great feel, not spongy and doesn't bottom out when you push hard, and no trouble codes. ABS/Speed sensor problem maybe? Any ideas? As always, the help is greatly appreciated.
Old Aug 29, 2013 | 10:48 PM
BigIron70's Avatar
Cummins Guru
If you have brake light only then chances are it's just park brake switch or park brake out of adjustment or stretched cable. Try lifting up on park brake pedal and see if light goes off. The ABS light would come on if you had a sensor go out on you. Also check to make sure your brake lights are working.
Old Aug 29, 2013 | 10:59 PM
mtb1982's Avatar
the parking brake is up all the way and making contact with the switch for the light and the brake lights are working. I'm thinking that the brake fluid level sensor on the reservoir is kaput. found the thread that had the part number for the sensor and ordered it. will have to see if that does the trick.
Old Aug 30, 2013 | 08:39 AM
BigIron70's Avatar
Cummins Guru
Disconnect the switch and see if light goes out, it's just a grounding switch to turn on light.
Old Aug 30, 2013 | 06:04 PM
mtb1982's Avatar
just an update, the brake lights are now on all the time when the ignition is on, but the third light (cab light) is not. replaced the light switch and no change. cab light works when brake pedal is pressed and main brake lights work properly when the ignition is off, and cruise control doesn't work. have both batteries disconnected and essentially putting the truck in time-out...lol. going to reconnect the batts in a few and see what that gives me.
Old Dec 23, 2018 | 10:42 PM
Michael Studer's Avatar
my brake lights are on as well the whole time the truck is running but when I turn the truck off they go off, this is after I took the heater core out to check it for leaks, after reinstalling the dash the red e brake light was on and went go off, the switch is making contact and the fluid is full in the reservoir. What can this be???
wcbcruzer
Jul 27, 2021 07:27 PM
coadman
Feb 22, 2016 10:36 PM
coadman
Jul 10, 2006 07:22 AM
Bobcat
May 12, 2003 09:14 AM
shrtmntdiesel
May 8, 2003 01:10 PM
