Cylinder 6 misfire
Old May 24, 2017 | 12:05 PM
Butcher24's Avatar
Cylinder 6 misfire
I have 06 Cummings and have replaced the #6 injector but still receive a misfire code. I double checked the injector and verified that it ohms out like the rest of the injectors so I have read that it could be a fuel issue? Can the FCA be the culprit or would it more likely be the lift pump?
Old May 24, 2017 | 03:07 PM
steelblitzkrieg's Avatar
DTR Detective
Did you Ohm at injector or from the harness.
I ask because the injector harness could be the issue, what code are you seeing?
Also what resistance are you seeing?
Old May 24, 2017 | 03:13 PM
Butcher24's Avatar
I ohmed at the injector and it ohmed the same as the rest. I don't remember what the ohms were
The harness is brand new also as I replaced two other injectors
Old May 24, 2017 | 04:53 PM
DTR Detective
What codes are you getting?
ironbrew
Aug 12, 2015 08:23 PM
RAM6SPD
Apr 1, 2010 03:31 PM
mattyfz450
Mar 18, 2009 10:30 AM
tomm
Jul 26, 2007 10:49 AM
Journier
Nov 22, 2004 02:56 PM
