Curious Observation... G 56 Casting Cracks?
Old Jul 17, 2007 | 10:23 AM
Roperteacher's Avatar
Hey there!! I changed the G-56 fluid out on my new 07 to install the Amsoil ATF4. After a couple days I just popped under there to make sure everything was tight and no leaks etc.. I noticed that the Outer casing of the G-56 unit has surface cracks that look much like tire chracks on tires that have been sitting in the sun a while. I am assuming this is just an outside blemish or something. I can't rememebr seeing them on my 06 G-56. THey seem to be concentrated on the bottom of the trans rather than the upper. I was just curious... Thanks!!
Old Jul 17, 2007 | 11:54 AM
Thanks to John Holmes over at Carson Dodge... He explained the cracks as completely normal... The G-56 is SAND CASTED and the cracks are a result of the casting process...
Old Jul 17, 2007 | 12:01 PM
Spooler's Avatar
Yeap, it is normal for an aluminum alloy case to have cracks like this. Need to put gloves on to remove it also unless you want a ton of paper cuts on your hands.
Old Jul 17, 2007 | 02:13 PM
If it's normal, then I don't really care about it.. LOLOLOLOL Was just an interesting observation... Not sure why I didn't notice it when I was changing the fluid, only when I went to go ck it! LOLOL
Old Jul 17, 2007 | 09:34 PM
D-Roc's Avatar
What did you use to get the fluid in your G56?
Old Jul 17, 2007 | 10:09 PM
mrblond's Avatar
I use a cheap gear lube hand pump I think made by Stalube.
But with the bigger G56 trans and the high volume of fluid that needs to be pumped I would buy the best hand pump available.
Usually by the third quart im pretty tired. I think the G56 takes at least 6 quarts, about 2 more quarts then the NV5600.
The cheap Stalube pump has a adaptor at the exit end of the hose which kinda hooks that end into the trans fill hole. Works good!
Old Jul 17, 2007 | 11:07 PM
Since I installed the AMSOIL fluid, I used an AMSOIL pump. THey are 10 bucks and fit nicely over all their quart containers. I use the same thing for the Differentials, etc..
wrenchmaster
Apr 20, 2009 08:42 PM
v8440
Oct 21, 2004 01:39 PM
Haulin_in_Dixie
Apr 3, 2004 01:47 AM
RedWhiteDiesel
Mar 8, 2004 09:44 PM
tool
Dec 27, 2003 02:27 PM
