crankshaft position sensor
Old Feb 28, 2009 | 07:56 AM
TrkEnvy's Avatar
My truck threw a p0336 last night and one of the guys on here looked it up for me on here and said it was crank position sensor.. It was running funny and I'm traveling back to vegas on this truck.. What does the crank position sensor do and how can I go about fixing it??
Old Feb 28, 2009 | 08:05 AM
JTProuhet's Avatar
Check your wire running along the AC line... There is a sticky at the top of this page.. I believe if it is shorting out it will mess with the CPS.. i dont know if it will throw a code or not but, maybe it isnt the sensor..
Old Feb 28, 2009 | 10:35 AM
RamWheelsBy4's Avatar
Check the wiring harness connector to the crankshaft sensor. Make sure it is not loose, frayed, etc. The Crankshaft Position Sensor (CKP) is attached at the front / left side of the engine next to the engine harmonic balancer (crankshaft damper). Did the CEL go out after 4 or 5 start/run cycles?
The crankshaft sensor is the primary engine speed indicator for the engine after the engine is running.
Wild Bill
Jan 21, 2005 03:35 AM
James Andres
Dec 20, 2003 04:42 PM
Two Dogs
Jul 11, 2003 09:12 AM
ATEAV8GN
Apr 1, 2003 08:03 AM
