Crank shaft sensor code issues
Old Jan 13, 2011 | 10:03 PM
horsehelper's Avatar
HI there folks ... great forum but the first time posting. I have a 04.5 with 220,000 miles on and I get the crank sensor code 336. I changed the sensor and I was good for about 3 weeks and again it starts to cough and the check light comes on and then it runs great. I found on here about the wire by the filter and sure enough I had the same problem. Again it ran for about 2 weeks and it started coughing again and same 336 code.
I get 24 mpg with lots of power but was wondering if you folks think that it could be the injectors or is there another wiring problem that is out there.
thanks
Old Jan 14, 2011 | 05:20 AM
CRXsi's Avatar
Also check the wire that is below the oil filter and on the ac line/ac compressor. It can chafe away on the ac fitting. There is a thread with pics in the forum about this as well.
https://www.dieseltruckresource.com/...re-t81936.html
Old Jan 14, 2011 | 08:57 AM
I did find this wire rubbed through but the guy that wrote the article talked about him having a cam shaft error. My poor truck keeps haveing 336 code. Can injectors or other wiring issues cause a repeat problem. The 336 code states crank shaft perforamnce error. I am not sure what that means.
Thanks
Old Jan 14, 2011 | 12:01 PM
El Borrego's Avatar
Crank Shaft Sensor
If you've patched the wires check to see if the cam sensor is properly aligned. This can also cause codes indicating cam sensor and/or injector problems. I had a similar issue and it was primarily the naked wires (pinched by the oil filter area) and the cam sensor. Once repaired and adjusted I had no more problems.
Old Jan 14, 2011 | 06:28 PM
So It seemed the old crank sensor was around .050 clearance but I am not sure exactly how far away it should be per the book. I did stick my head under while it was running and it seems the that the notched wheel that it is reading is not going around perfectly smooth. I have not put an indicator to see how out around but does this evan matter. What should the clearnce be and is there a way of verifing that the crank sensor is working correctly.
Thanks so much for your input.
Old Jan 16, 2011 | 10:05 AM
alboy's Avatar
I just went thru the crankshaft sensor issue,mine had the exact same issue as yours,turned out to be the connectors in the harness right where it goes thru the condenser.No more problems since.
Old Jan 16, 2011 | 11:46 AM
I will go take a look at the actual connector and see if there is aproblem there.
Thanks for your help.
Det 1
17
Dec 22, 2009 08:32 AM
acukwik
Sep 30, 2008 10:32 PM
Crossy's son
Jun 25, 2008 08:13 PM
darrenG
Jun 13, 2005 07:49 AM
kingofdodge7131
May 24, 2004 01:09 PM
