Crank, No Start
Old Dec 22, 2008 | 06:42 AM
Names_TJ's Avatar
Crank, No Start
Alright, it was a lovely 4 degrees this morning and the truck started fine, a little rough at first but wasnt too angry. I get out to clean my windows off and it dies off. It was doing fast idle as soon as I started it up. Started it 4-5more times and it would start but die off. If I push the gas it would rev up and die off again. I have not put any additives for anti-gel in her for a while. My first guess was lift pump - mainly because I was researching them last night! ha. What do you guys thihnk? Pump? Gas gelling? If it is the pump how could I test for it?
Old Dec 22, 2008 | 07:42 AM
Hounddog's Avatar
My first guess is water in fuel and its iced/frozen.How often are you draining your fuel filter cannister? I don't think the WIF warning light works on any of these trucks.Pull the cannister lid and pull the filter and see whats in there.You can also drain it then and with lid off hit the key and see how quick it refills with fuel etc.
Old Dec 22, 2008 | 08:39 AM
anpconnors's Avatar
Try Power Service 911
Just had mine stop in the deep woods @ -10 F Had to get towed back to the hunting shack by a Chevy.... Swapped Fuel Filter added 911 and fresh fuel, put balance of 911 in tank and she was off to the races. Good luck.
Old Dec 22, 2008 | 12:22 PM
Names_TJ's Avatar
Sweet I will try that after work. Anyone has have similar problems?
Old Dec 22, 2008 | 07:19 PM
Names_TJ's Avatar
OK, there was actual ice on the fuel filter. Drained the canister, new filter, 911 solution and all is better now. took a few cranks to actually run but shes fine now! Thanks guys
Old Dec 22, 2008 | 07:30 PM
dozer12216's Avatar
From the number of post I'm seeing it is apparent that fuel companies got caught with pants down on climatized fuel. Or perhaps it has been a long time since you fueled up and stock is several weeks old. A word to wise is go out tomight and get a quart of your favorite anti-gel material and use on way home. I'm on my way to cold country tomorrow. I will be prepared, hopefully.
92smokin blacky
Feb 28, 2011 02:36 PM
CoolumConst
Oct 11, 2008 10:00 PM
bsj04
Feb 18, 2008 06:06 PM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
