cost of ATF+4
Old Jan 9, 2008 | 10:37 AM
Hounddog's Avatar
The HIGH END is a Group 4 which from what I know is a pure syn.that is able to go longer drain intervals.Same with oil.Lots of group threes call them selves synthetics but are on the lower end of the scale.
Old Jan 9, 2008 | 05:44 PM
davelinde's Avatar
yep... so for sure I'll be buying ATF+4 from someone cheaper than Mopar if it's the same stuff.
I guess I was wondering about the AMSOIL version for mixing in... since if you listen to those guys the AMSOIL will somehow drop transmission temps and increase fuel economy and practically drive the truck for you.
This time around I've got a $100 of ATF+4 in my garage to use. Next time we'll shop. I like to drain/refill my pan every 20,000 or so to keep a good mix of ATF in there all the time (my theory at least)
Old Jan 9, 2008 | 05:58 PM
Hounddog's Avatar
The Group 4 synthetics(Amsoil is just one of them) do pretty much as advertised.Its in my transfer case of my 03,the auto trans in my 98 1500 and my 06 Mercury Gran Marguis. Its all I put in a auto trans.Over the years I've had several engineers withen several differant areas of the auto trans market say the same thing.Use a top shelf synthetic trans fliud and cut your chances of a failure.Why do you think Chrysler went totaly for previous and late models to ATf+4? Same way of thinking apprently as the engineers that mention to me the same thing.
Old Jan 9, 2008 | 06:02 PM
sallyman1's Avatar
you can probably get a cheap afe stage 2 on ebay for like $500. Maybe a used one for $300. or wills whistler homemade filter for $120 (with more airflow just not as nice) its up to you>?
Old Jan 9, 2008 | 06:18 PM
Hounddog's Avatar
Sallyman1 did you post on the wrong thread? Thought I was only one to do that.
Pig
23
Jun 4, 2010 01:01 PM
CTDowerTN
Dec 8, 2006 09:15 AM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
