Is this the correct stuff????
CP3 systems are designed to run within specific viscosity range - too much 2-stroke could have detrimental effect on engine operation, thru the injectors
There are always those who think if x is good, xxxx is mo' bettah - someone throwing two quarts oil in with the fuel can expect less than good results, for example.
And those who forget mixture ratios when topping off - it's all subjective.
MMO was formulated to clean sludge and gunk outta gasoline engine systems - 2-stroke motor oil was formulated to lubricate all engine components, and then be burned in the combustion chamber
I select each, according to it's intended useage, for what I intend to use it for
brendangsxr
Nov 21, 2006 04:40 PM
Relentless
Oct 6, 2003 06:46 AM
barracuda
May 11, 2003 10:27 PM
