Cooler Line Manifold
Old Apr 2, 2008 | 01:52 AM
jery1134's Avatar
I just ordered a set of guages from Dielsel Manor. I got the ISSPRO 3 guage with boost/Pyro/trans temp. I have searched on here and can not find what size the transmission cooler line is so I can by the appropriate Cooler Line Manifold. By looking at it if figured 3/8 but not for sure. What is everyones take on this temp?
Old Apr 2, 2008 | 02:23 AM
trik396's Avatar
Diesel Manor sells what you need... call em'.
Old Apr 2, 2008 | 05:56 AM
Scottygl62's Avatar
The hot line Ibelieve is 1/2-inch.
Old Apr 2, 2008 | 02:50 PM
zuki_dan's Avatar
The line is 1/2. I used -8 an tube nuts/sleeves from summit and put my adpt. in. It cost about $30 to make.
Old Apr 2, 2008 | 10:57 PM
N.Johnson's Avatar
It's 1/2" O.D. in the hard line. You can go cheap with compression fittings. They work but will eventually leak, ( I had it happen) don't take too repeated heat cycle expansion/contraction. Do it right the first time and use JIC flare fittings or whatever you call them in your neck of the woods.Diesel manor sells the complete line. Save the hassle!
isb07
Nov 18, 2009 05:12 PM
silkywoods
35
Feb 6, 2008 12:40 PM
RoadDiesel
Jun 16, 2007 09:24 PM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
