coolant leak
Old Jan 13, 2005 | 09:36 AM
tbromley08's Avatar
Angry coolant leak
Anyone have a water pump gasket leaking? I have already had it replaced once and it still leaks in the same place!!!!!! 15000 miles
Old Jan 13, 2005 | 09:56 AM
truckjunkie's Avatar
Where exactly is it leaking from - i.e. where do you see the coolant?
I had a bunch of coolant pooling at the very bottom of the radiator, near the petcock valve. I figured it was the valve itself, but finally discovered it was the upper radiator hose - the spring clamp wasn't sealing correctly; but it took me a freakin' week or more to finally find it. What a pain.
Old Jan 13, 2005 | 02:02 PM
Hemi Cat's Avatar
If it's by a bolt, try using pipe sealant on the threads. Also check for the leak coming from a different location and dripping down or blowing in from the rad.
Old Jan 13, 2005 | 11:38 PM
J BODY's Avatar
Notice lots of seepage on the trucks and the cars since going to that new "better" red coolant.
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
george7941
Nov 28, 2009 09:28 PM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
