Coolant leak
Coolant leak
So like many other's I thought my truck had a trans leak this morning when I went out to start it. After getting under the truck I noticed that it was coming from that little hose for the coolant right by the turbo. I could not believe how loose the clamps were on the hose. I tightened them up but I doubt that will last very long. I remember that there was a replacement hose and clamps some people were putting on, but can't remember what the part number's were?
Thanks
Thanks
Main reason I switched back to the "green" stuff... not enough benefits to warrant the hassel/confusion in identifying a red trans leak vs. a red coolant leak! Switched over a few months ago which really helped diagnose a leaking water pump! If I'd stayed with the "red" stuff I'd still be looking for the problem! Upon 1st sight...there's just no mistak'n a fluorescent greenish/yelllow puddle...even nature seems to agree!
RESPONSE FROM "PEAK"...
(Bill) Thanks for your e-mail. Final Charge is an Extended Life Heavy Duty Coolant, which is a phosphate-free, silicate-free, nitrite free formulated coolant which provides superior wet sleeve liner cavitation and corrosion protection. The Final Charge eliminates the need for SCA's, the only maintenance required is the addition of the Final Charge extender @ 300,000 miles.
We also offer PEAK GLOBAL LIFETIME ANTIFREEZE & COOLANT [which] is a new coolant technology that can be used in all automobiles worldwide, regardless of make, model, year or current antifreeze color. PEAK GLOBAL LIFETIME ANTIFREEZE & COOLANT is based on patented organic acid technology (OAT) and uses patented advanced engine protecting inhibitors to provide maximum protection against damaging rust and corrosion in all automotive cooling systems. The patented antifreeze/coolant technology provided in PEAK GLOBAL LIFETIME ANTIFREEZE & COOLANT has been rigorously tested and has passed all performance specifications.
[1] PEAK GLOBAL LIFETIME ANTIFREEZE can successfully be used in your Dodge.
[2] PEAK LONG LIFE [& PGLA] can both be used in all makes and all models and can also be mixed together.
[3] One main difference between the two is that PEAK GLOBAL LIFETIME is a premium product with a special corrosion inhibitor that allows us to offer a lifetime warranty.
[4] PEAK LONG LIFE utilizes an older yet still good extended life technology inhibitor package that is designed for 5 year 150,000 mile protection.
PEAK Tech Dept.
PEAK Tech Dept.
The dealership by me could not find the part also which does not make a lot of sense. I went to dodgeparts.com and it came up when I put in the part numbers. I think the hose was 12 bucks from them.
The hose isn't going to fix anything. You need to get the other clamps. Mine leaked a few weeks ago so I tighened the worm gear clamps, and it started leaking again today. Your going to need the self adjusting clamps as well as the hose.
I will see if I can find the post I made that a few guys had the part numbers for the clamps. Or you might be able to find some at the auto store.
Edit: Well I found my post about the same thing, no part numbers for the clamps in there. It must have been in a differant thread sorry.
So here are the part numbers you REALLY want!!!! They are the Cummins Part numbers from the parts I purchased from the Dodge Dealer. And yes, whoever has purchased them from the dealer was ripped (just like me)....
Hose - 4939438 (almost 1/3 of the cost of the dealer)
Clamp - 4930327 (of course you will need 2)
