Considering '03 w/Auto, need advice
Old Oct 22, 2005 | 09:05 PM
krmorr's Avatar
I am looking at an '03 with an automatic transmission. I am not familiar with this transmission and know that it is new for the '03. I believe it is a 5 speed. The transmission selection display show P RND21 with an O/D on the shift lever. How good is this transmission. The truck does not seem to accelerate well enough, but neither did the new '03 I drove back in '03.
Any opinions and advice would be appreciated.
Oh ya, I have a 11.5' camper and will be towing a boat behind the camper. I may puchase a 5th wheel to replace the camper. So, tow ability is important.
Old Oct 22, 2005 | 09:20 PM
The Domie's Avatar
We all need some more info on the truck - - SO or Ho? if its the HO you're good to go (cause it has the 48re) SO has the 47re. Gears?
Auto is a 4spd. overdrive. 03 gets the best mileage of the 3rd gens.
Good luck!
Old Oct 22, 2005 | 09:41 PM
krmorr's Avatar
I believe it to be a SO, though I am not sure how to confirm that. Is there a way to know for sure? Will the VIN identify that? I have access to the VIN.
Old Oct 23, 2005 | 12:04 AM
drew03's Avatar
ditch the auto go 6 speed
Old Oct 23, 2005 | 12:18 AM
J BODY's Avatar
Sticks are for popsicles!
post the last 6 of the vin.
Old Oct 23, 2005 | 01:33 AM
qmcdt's Avatar
Look at the plate on the engine. ISB250 is th SO and the ISB305 is the HO.
Old Oct 23, 2005 | 06:33 AM
Dodgezilla's Avatar
Put a box on it and it will accelerate just fine.......
Old Oct 23, 2005 | 08:26 AM
Mr. Jimmy's Avatar
I think that if it is a S.O it would still be a good tow vehicle. I had a 99 CTD rated at 215 HP before buying the 03 and never had any complaints with the towing ability. Not sure I would go with a 6 speed again as I did due to probability of lack of parts in the future for the NV 5600 as production has stopped.
Old Oct 23, 2005 | 08:35 AM
Big Ed's Avatar
Model Year 2003 is a sticky year. Depending on configuration this truck could have the standard output/47re transmission. The 47re is the old transmission and is weaker than the 48re. On the other hand it could be a High output/48re transmission. The 48re was not introduced until 1/1/03. Therefore, early 03's built prior to 1/1/03 that had an auto were all SO/47re. However, all trucks built after 1/1/03 regardless of engine output utilize the 48re. As stated, check the engine data plate to determine horsepower.
Old Oct 25, 2005 | 10:10 PM
Tundra Maggot's Avatar
right, I actually have an SO with the newer 48 tranny.
needadiesel
Nov 1, 2011 10:54 PM
archer39
Feb 20, 2008 03:02 PM
