codes 0633 2509 2149 2146
Old Nov 2, 2008 | 03:02 PM
Codyboy's Avatar
I have the following codes and wondering what you guys think, I thought maybe 2146 or 2149 would mean a bad injector possibly but not both. As well 2509 could be related but dont know. I thought maybe a bad alternator could be it but seems to be charging fine just a little noisy. I have read a few posts but not sure where to start and if they could share a common problem.
P0633 SKIM Key Not Programmed in PCM
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2509 ECM/PCM Power Input Signal Intermittent
Thanks
Old Nov 2, 2008 | 07:25 PM
bob4x4's Avatar
Thanks
Are you using a box that ties into the injector harnass ?
Old Nov 2, 2008 | 07:46 PM
rip 112's Avatar
Bad injector, probably #3 or #4. My friend just had his #4 injector replaced and he had those exact codes. My ? is the truck running rough?
Old Nov 2, 2008 | 08:25 PM
Codyboy's Avatar
nope the truck runs pretty good. No noticeable smoke. I did notice that sometimes it likes to idle around 1000 rpms and then it will idle around 800 little later
How can i check the injectors?
Not sure what you mean by a box that ties them together
Old Nov 2, 2008 | 09:18 PM
05CTDN8's Avatar
Are yo using an MP-8, TST, EDGE, ........
Old Nov 2, 2008 | 09:29 PM
Codyboy's Avatar
opps read that wrong. I never used a chip on it. I have only had the truck for a week so cant say what the other owner did but it looks like there wasnt one on it. But there are a couple wires i dont know what they are for and they are not original and are integrated with the harness on the drivers side
Old Nov 5, 2008 | 10:24 PM
Codyboy's Avatar
seems like i am getting crappy mileage. Anyone know how to check to see if the injectors are bad? Never done it so a write up would be awesome
Topper
Jul 9, 2009 02:50 AM
badablackdodge
Sep 24, 2008 07:24 PM
cincydiesel
Sep 18, 2008 11:42 PM
nathan04
Apr 30, 2007 12:51 AM
MoparKen
Sep 4, 2006 04:56 PM
