code p0628
Old Nov 7, 2007 | 10:51 AM
johndeere01's Avatar
code p0628
on my way to work this morning truck quit, started shut off again started fine and ran fine the rest of the way to work P0628 is the code it is showing fuel pump relay circuit low, fuel pump control circuit low, my battery temp sensor is bad and gettin replaced tuesday what do you think it wrong this will be the 12 time in the shop since april bought it with 61,000 now has 71,000 and nothin but problems
thanks
Old Nov 7, 2007 | 08:21 PM
no one knows?
Old Nov 8, 2007 | 06:23 PM
update truck is dead in the drive way turns over for awhile and then fires and runs for 4 seconds an shuts off no idea whats goin on with it,stock truck changed filter 1000 miles ago was running fine an now nothing
thanks for the help
Old Nov 8, 2007 | 07:03 PM
jrussell's Avatar
Maybe a bad lift pump?
Sorry man, can't really help much cause I'm not sure what lift pump the 04's use.
Old Nov 8, 2007 | 08:23 PM
thats what im think just wondering what i could do to check it gives code P0628
thanks
Old Nov 8, 2007 | 08:41 PM
crackcorn's Avatar
Your code is "Fuel pump relay control circuit low voltage." If you or any one else needs codes you can go to www.allpar.com/fix/computer-codes.html
Old Nov 8, 2007 | 08:43 PM
crackcorn's Avatar
Duh, guess you allready new what the code was sorry don't have any idea on cause. Interested in knowing what you find out.
Old Nov 8, 2007 | 08:48 PM
Itsmejoe231's Avatar
Sounds like you lost power to your fuel pump. check for a loose connection or a bad fuse.
Old Nov 8, 2007 | 09:30 PM
alright will do the fuel pump is on the back of the filter canister right? thanks for the help
pind's Avatar
I am currently dealing with an 0628 on an early 04 here. The lift pump on this one is shot, same symptoms you are describing. This truck has the LP located on the filter canister, and the gentleman believes that stock is best, so we are going to put the updated "in tank" LP system in for him.
Old Nov 8, 2007 | 09:32 PM
thanks again
Old Nov 9, 2007 | 11:22 AM
ok this morning took fuel filter out and it was clean while the cover was off i turned the key on and the fuel pump was pumping fuel could hear it running and see it pumping put filter back in turned key on waited about 20 seconds an fired off an ran fine. My question is when these pump are about to go will they get hot and quit working then after they cool off start working again? or do they just quit and thats it?
Old Nov 9, 2007 | 02:02 PM
vzdude's Avatar
DTR's 'Go to Guy'
I have seen those pumps quit, cool down and start working again, also a little jolt can make them majically come back to life ( i.e. hitting the pump gently! ) A lot of times I get vehicles towed in, I can hit the tank ( other trucks/cars) and get the pump to run enough to get it in the shop. I'd repalce the pump. When this code sets, it basically is because the pump is either not drawing enough amperage, or too much amperage. The computer monitors that in a round about way.
Old Nov 9, 2007 | 02:11 PM
Spooler's Avatar
That code is related to a bad LP. That is the same exact code mine gave me when the LP started acting up at 24,000 miles. If it is under warranty you can get a factory in tank LP installed or opt for the GDP lift pump kit which is what I would do. Going to an aftermarket one after they install the factory in tank LP is a pain to do. You have to install a draw straw in the fuel tank. If you are going to leave it perty much stock the factory in tank LP works just fine.
Old Nov 9, 2007 | 02:14 PM
jthorpe's Avatar
DTR Founder
That's the code i got before my VP-44 died on my 99.
