clutch aftermarket
Old Nov 24, 2005 | 05:18 PM
StrokeThis2500's Avatar
clutch aftermarket
think i have an aftermarket clutch my truck is an early 04 6 speed the pedal is pretty stiff and if i put in second and just let off the clutch and just let it idle it makes this weird rattle noise what is that noise and how can i tell if its an aftermarket clutch or not
Old Nov 25, 2005 | 02:34 PM
bluebull's Avatar
If you just let the clutch out and don't give it any throttle mine does the same noise thing. I have heard many manuals do this, it's normal.
As for telling if it's an aftermarket clutch I couldn't tell yah how to tell.
Old Nov 25, 2005 | 05:36 PM
Mexstan's Avatar
Seems to me that I read somewhere of a SB on clutch rattle. Think it was for the 2003's but it may also apply to later models.
Old Nov 26, 2005 | 09:59 AM
jarmar's Avatar
Never heard mine do that.
jr
Old Nov 26, 2005 | 06:01 PM
bluebull's Avatar
It does it more loudly when the transmission is cold. Next time after the truck sits all night start truck in normal way roll your window down so you can hear take off on level ground do not use throttle let truck get up to speed on it's own and then slow down on it's own you will hear it. The trick is to let truck do it without you useing throttle. The noise I'am referring to is more of a err, err, err noise.
Old Nov 26, 2005 | 06:30 PM
i hear that noise but do yall guys use the throttle when starting off or just let off the clutch all the way then press on the throttle cause i was told to just let off the clutch then press the throttle
Old Nov 26, 2005 | 07:11 PM
CASMOKIN's Avatar
I just put in a Haisley street Drag, @ idle it sounds like a UPS truck
Old Nov 26, 2005 | 07:53 PM
jarmar's Avatar
I release the clutch and after the truck begins to roll begin to apply the go pedal, even when towing my fifth-wheel. I thought that was the way it was supposed to be done.
jr
Old Nov 27, 2005 | 03:44 PM
supercharger's Avatar
I have never used throttle to take off. Guys that are used to gassers tend to use throttle on take off. There is absolutely no need on a cummins, a powerstroke or duramax maybe. It will just wear your clutch more if using throttle.
Old Nov 27, 2005 | 10:23 PM
strokethis600's Avatar
when i got my drag twin clutch it rattles, because it does not have any dampeners.
Old Nov 27, 2005 | 11:12 PM
DR3500's Avatar
This is normal, the engine is slightly below normal idle and is lugging a little, mine will do it in the higher gears also if I lug it below the normal idle speed.
I just let the clutch out(slowly) and then give it throttle to get going, if you let the clutch out too fast it will do the above.
M0J0
Jun 14, 2006 11:20 AM
06bluetank
13
Jun 13, 2006 12:49 AM
I PASS GAS
Mar 16, 2006 07:59 AM
StrokeThis2500
Nov 23, 2005 11:02 PM
ET_178z
Jul 19, 2003 01:00 AM
