Clunky lose something in front
Old Mar 14, 2007 | 08:29 AM
pcburnout's Avatar
My 03 truck and my friends 05 have something that sounds lose from frontend when you go over a jarring bump. Both trucks are lifted! I have checked everything but all seems tight. Not sure what ratties has anybody else have same noises from frontend. Any replys would be helpful as this noise has got to go!
Old Mar 14, 2007 | 10:13 AM
TonyB's Avatar
Check the steering shaft between the sterring box and the steering wheel.
HTH
Tony
Old Mar 14, 2007 | 07:52 PM
djbikeman's Avatar
Check the above for sure. Also check the track bar end links. I had one go bad in about 9 months. It would only clunk going over bumps. You can't tell it is worn or has play if you are just pulling and pushing on the steering linkage or track bar, but once you pull it out, it will be obvious. It only takes a minute to remove and check.
Old Mar 14, 2007 | 10:18 PM
arcojet's Avatar
This might sound silly but check the coolant level in the overflow bottle. Mine got a little low and when it sloshes around it makes a clunking sound.
Old Mar 15, 2007 | 11:08 AM
notblowingsmoke's Avatar
Same here, thought it was somthing loose but just the coolant!
Dodgezilla
May 24, 2011 12:24 PM
MoparNut
Jan 18, 2010 09:22 PM
ramdez
Dec 28, 2009 03:55 PM
bigragu
Sep 8, 2006 03:23 PM
admin
Site News
Oct 7, 2002 02:21 PM
