clunk in brand new CTD??? Normal?
Old Aug 27, 2005 | 01:26 AM
desertram800's Avatar
I have an '05 ram 2500 CTD 4x4 automatic. My question is, is it normal when accelerating from a stop, or really slow, to around 10mph, and if I let off the gas, I feel a clunk, like it shifts really hard, but this is only when I let off the gas, and it only happens at speeds around 5-10 mph.
Also, one other nonrelated question, does anyone els'es hitch fit just a tad loose in the reciever and clunk when hitting bumps? What did you do to shut it up?!?
Old Aug 27, 2005 | 04:43 AM
Dodgezilla's Avatar
My trans does that too. It's still shifting into second gear even though you let off the accelerator pedal. Kind of like you passed the point of no return for shifting and when you lift your foot the trans says "Now what am I supposed to do?" Get used to it if you sit in stop and go traffic. I have had that problem with every vehicle I've owned from Mustang GTs and Trans-ams, to Ford trucks and Chevy trucks. You will learn to drive your truck so that it doesn't do it all the time......
As far as your hitch, something is wrong there. Are you sure you don't have a class II or III reciever in your Class IV hitch? I saw a dually running around a couple months ago like that.
Old Aug 27, 2005 | 06:22 AM
handymantim's Avatar
Do you have the correct size hitch pin? They make a 1/2" and 5/8" hitch pin (the pin that slides through the hitch and reciever).
If you don't tow that much you could remove the receiver when not in use.
You could buy a new receiver.
You could weld a couple beads on the sides of the receiver and then grind them down until the receiver fits just right.
Old Aug 27, 2005 | 08:49 AM
nickleinonen's Avatar
plastic shim between the draw bar and the hitch will eleminate the clunking noise [my pop pressed in a SS shim into his trucks reciever and now that draw bar will not come out ever without torch...]
some silicon sealent spread thinly around the draw bar and set to dry then installed will also cushion the clunking.
that is normal to me. i see no problem with it [the 2" od and 2" id fit of the parts isn't a very precice one. there is allowed like 0.050" play up/down and left/right...]
Old Aug 27, 2005 | 09:54 AM
thanks nickleinonen! I think I'll try that silicon sealent first. And for you others, YES, it's the correct type of hitch and it's the correct size pin. The gap is very tiny, it's just that I have a big, heavy military style hitch with the big top folding piece as well as the ball. It's big, and it's actually saved my rear bumper on my old truck twice when rearended!
Old Aug 27, 2005 | 08:23 PM
JAF's Avatar
JAF
Re: clunk in brand new CTD??? Normal?
[QUOTE]Originally posted by desertram800
[B]I have an '05 ram 2500 CTD 4x4 automatic. My question is, is it normal when accelerating from a stop, or really slow, to around 10mph, and if I let off the gas, I feel a clunk, like it shifts really hard, but this is only when I let off the gas, and it only happens at speeds around 5-10 mph.
Mine has done it since day one
Old Aug 27, 2005 | 08:27 PM
Dodgezilla's Avatar
I keep my drop hitch back there for the same reason! It sucks when I bang my knees into it, but if someone hits me it's gonna absorb a bunch of the impact..
Old Aug 28, 2005 | 02:36 PM
HOUTEX's Avatar
YEP nothin starts the day like bangin a knee on the hitch, I mean
one of those good truck rockin bangs that leave a mark for a week....
Old Aug 28, 2005 | 07:23 PM
bluepp's Avatar
Or a chunk out of the shin bone!!!!!!! When that happends you learn to walk AROUND IT.HAHAHA
Opus
Mar 14, 2011 01:12 PM
Cummins610
17
May 29, 2010 12:50 AM
MasseyMan1089
May 23, 2007 07:56 PM
teqmod
Dec 30, 2006 01:27 PM
dpeder
Feb 21, 2006 11:34 AM
