Clicking when I turn the steering wheels
Old Nov 11, 2011 | 08:37 AM
reddodge225's Avatar
When I'm driving and I turn the steering wheel to a certain point I start to get a clicking sound everyonce in a while. Its actually coming from around the steering wheel, it's not a u-joint or nothing like that. I have also noticed that when trying to get into a parking spot or anything where I'm steering the truck while run low rpms I have to crank on the wheel like I have no power steering. Plus just yesterday I noticed at idle the trucks is making a different kind of vibration at idle, but quits when give it a little throttle. Could this all possibly be linked to the power steering box?
Old Nov 11, 2011 | 08:48 AM
89dieselkong's Avatar
If it is popping when you turn it, like it turns easy and then not then easy again etc. you might have air in your system. I would do the normal checks, belts, fluid level etc. Sounds like it might be the pump otherwise.
Old Nov 11, 2011 | 08:55 PM
.boB's Avatar
I seem to remember something about a clock spring problem. The clock spring is inside the steering wheel, behind the air bag.
Old Nov 11, 2011 | 09:51 PM
RTillery's Avatar
My 04 is doing this again. A couple of years ago it was getting pretty noticeable. Clicking badly enough that I could almost feel the clicks. I put the front end on jack-stands and disconnected the batteries, pulled the airbag and worked my way down. I thought pulling the clockspring would eliminate it but no luck. I finally pulled the steering wheel and there is a cheap looking open ball bearing supporting the top of the steering shaft. It has exposed ***** like a bearing in a kids bicycle wheel. It looked OK but pretty dry so i greased it and it helped significantly. I still had an occasional pop but much better than before.
After a couple of years it is not as bad, but starting to come back.
May 31, 2012 09:49 AM
RonP
Jan 28, 2010 08:30 PM
masonpauls
Mar 6, 2008 10:06 PM
Txwelder
Jun 28, 2007 05:10 PM
FirstDodge
Jun 19, 2007 09:25 PM
