Charging
Old Nov 16, 2014 | 11:18 AM
bishgeo's Avatar
Charging
Volt meter has always been 14 solid now it's up to 15.1 at batts with multimeter. Origional alt and batts I guess it's time for new alt not much sense in trying to repair it.
Old Nov 16, 2014 | 08:20 PM
rockcrawler304's Avatar
Could be ECM. The ECM controls the voltage output from the alt.
Old Nov 16, 2014 | 08:43 PM
Jbremount's Avatar
Prob not a alt problem. Maybe your crossover cable is corroded and is not charging both batteries equally. More than likely, not charging the driver side battery. The ECM sees low charge on driver side battery and increases the charging level. I would clean, then check the crossover cable for continuity with a voltmeter.
Old Nov 17, 2014 | 09:47 PM
Spooler's Avatar
It will charge more in the cold weather. Nothing to worry about. It's a Dodge thing. May be time for batteries real soon. Alternator is fine.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
The_g10
Oct 30, 2002 07:47 AM
