Changing Tranny Filter
Old Jan 16, 2008 | 10:40 AM
bansh-eman's Avatar
Changing Tranny Filter Few Questions
when i change my tranny filter how much and of what type of fluid do you guys like to use to refill it? any tips i need to know when changing it? or is it as simple as draining it, removing the pan, replace old filter and gaskets, seal it up, and fill?
Old Jan 16, 2008 | 05:34 PM
DBLR's Avatar
When I had my trans filter replaced at 10K it took 6.5 qt's of AFT+4 trans fluid. Being Valvoline makes AFT+4 fluid now some people like to use it rather then Mopar brand of AFT+4 and some others like to use Amsoil ATF fluid. No matter what brand of fluid you use make sure that its ATF+4 and not AFT+3 or Dexron. IIRC the pan gasket is reusable if you take care when dropping the pan.
Old Jan 16, 2008 | 05:52 PM
bansh-eman's Avatar
thnx... btw whats IIRC?
Old Jan 16, 2008 | 10:27 PM
kokalit's Avatar
Acronym for If I Recall Correctly
Old Jan 16, 2008 | 11:17 PM
bansh-eman's Avatar
ahh thnx...
i just went to napa and got a new tranny filter kit and a new fuel filter... they gave me a napa gold fuel fiiter and a napa tranny filter kit.... are they good to run or are they garbage?
also for greasing points i can use just plain run of the mill lithium grease right?
Old Jan 17, 2008 | 12:13 PM
bansh-eman's Avatar
anyone?????
Old Jan 17, 2008 | 12:36 PM
DBLR's Avatar
I used the stock Dodge trans filter as my local Napa said there book did not show the 48RE trans and it was only $20.00 from Dodge. Also it would of cost me more to buy one online and pay shipping. Anyway as for fuel filters I once used Fleetguard Stratapore but I'll be switching over to the Baldwin PF 7977 as its a 5 micron fuel filter and it specs better then the new Fleetguard 7 micron. IIRC the Napa Gold is still a 10 micron filter, their EX is a 7 micron as per a post about them. BTW both Cummins and Dodge want us to use a 7 micron filter and not a the 10 micron like they used in early 2006.
Old Jan 17, 2008 | 12:38 PM
bansh-eman's Avatar
so your saying the tranny filter is fine but i should return the fuel filter for a micron 7 or lower?
D384D
14
Oct 26, 2010 10:23 AM
mx684
Jan 7, 2007 06:26 PM
BigBlue
34
Apr 17, 2005 08:28 AM
debolton
24
Jun 29, 2004 09:22 PM
Voss
Sep 4, 2003 10:11 PM
