Changing Tranny filter...
Old Jan 6, 2007 | 04:57 PM
mx684's Avatar
I got a new filter for my tranny to see if that would help anything....just got done taking it apart and theres an arm in there beside the filer on the passenger side...and it appears to have sum play in it...there seems to be an adjustment to take that out, but can anyone tell me if thats supposed to have play in it???? or should i try to tightin it up before i put it back together??????
Old Jan 6, 2007 | 05:06 PM
Shovelhead's Avatar
Administrator / Scooter Bum
If the tranny is shifting OK, I wouldn't mess with the settings.
If it's NOT, use these instructions and an INCH Pound torque wrench to adjust the bands.
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Old Jan 6, 2007 | 05:22 PM
mx684's Avatar
Thanks alot. i appreciate it!
Old Jan 6, 2007 | 05:32 PM
John DiMartino's Avatar
arm towards rear is reverse apply lever.To adjust go in 72" lbs,then back out 3 turns.If you dont have an inch lb torque wrench leave it alone. Arm in front is the front band(2nd gear). The front one i would adjust while your in there,it should have 1/4" of play,(use a 1/4" allen to check it).The adjuster is on drivers side if trans case,you need a 3/4" wrench ,and a T30 Torx.
Old Jan 6, 2007 | 06:38 PM
mx684's Avatar
I found quite a few metal shavings and one peice of broken metal about an inch long...so there are deffinatly sum issues with it...i didnt have a torque wrench so i left those adjustments alone and put it back together
Old Jan 6, 2007 | 11:12 PM
XLR8R's Avatar
What's your plan to discover what the broken internals of the tranny are?
Old Jan 7, 2007 | 06:26 PM
mx684's Avatar
i'm just locating all my parts i need to put in the manual and im gonna keep driving it like it is till i have everything then switch it out...once its out i might see if its not sumthing too major ill fix and sell it...or just sell it as is...
D384D
14
Oct 26, 2010 10:23 AM
bansh-eman
Jan 17, 2008 12:38 PM
BigBlue
34
Apr 17, 2005 08:28 AM
debolton
24
Jun 29, 2004 09:22 PM
Voss
Sep 4, 2003 10:11 PM
