Changing Manual Tranny Oil - Any Suggestions?
Old Dec 28, 2004 | 12:35 AM
HighTen's Avatar
Question Changing Manual Tranny Oil - Any Suggestions?
I'm ready to change the oil in the transmission. I got some Redline MTL at the local Summit and some black Permatex also. I plan on taking the PTO cover off so I can wipe out any solid material in the bottom after the oil is drained.
So I guess after taking the PTO cover off, you can just scrape the old gasget material off and put some fresh Permatex on?
Thanks for any suggestions or wisdom.
Old Dec 28, 2004 | 02:26 AM
nickleinonen's Avatar
yep... you can also grab the magnet in the bottom of the tranny and clean it up too... i used a razer on the transmission to scrape it clean and then some brake clean to make it non greasy... on the cover, i used a gasket grinding disc on a air sander, but a razor would do too... clean and non greasy makes it seal best for the gasket
Old Dec 28, 2004 | 06:04 PM
HighTen's Avatar
Thanks for the tips.
I'm glad this fluid replacement job sounds pretty basic.
Old Dec 28, 2004 | 11:29 PM
Nevada's Avatar
Take out the bottom PTO bolt first and let it drain.
H BROWN
49
Aug 1, 2019 01:13 PM
georgboy
Sep 12, 2008 04:51 PM
NM3500HD
22
Jan 7, 2008 07:57 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
Palmetto_kid
Jun 28, 2004 07:14 AM
