Changing gear oil
Old Oct 2, 2009 | 02:33 PM
Pull Ya's Avatar
The bolts twist off reeeeealy easy. You don't need a 6' breaker bar.
Be gentle---
Jay
Old Oct 2, 2009 | 06:00 PM
br6ad's Avatar
I just did mine last week. I used just under 7 Qts of gear oil. I used mobile 1 75w-90. I cleaned around the covers before I removed them. Once the covers had been removed and the oil drained I put a towel over the gears to catch any dirt that could fall in. I then wiped the contact area around the differential. I let it drain for about 15 minutes. I cleaned the cover and seal as well as the fill plug since there was some metal build up on it. I installed everything and filled them so that the oil just started coming out of the fill plug. I did note that the factory oil level was at the same height before I drained it.
Tips:
Remove the fill plugs before draining to make sure they will come out. Do a quick oil level check with a flashlight just to see what the factory level is before you drain.
I used an air gun to remove as many bolts as I could reach. I used an extension as well as a swivel joint to get to a couple of them.
You may have to raise the front end a bit at the frame in order to gain easier access to the bolts.
Torque cover bolts to 25ft-lbs. From all of the info I read on here this seems to be the most important. 30ft-lbs(Service manual spec) seems to be hit and miss for breaking the bolts.
Torque fill hole plug to 24ft-lbs per the service manual.
I had an extra 18" of clear tube laying around that I used to fill the diffs with. Make sure it doesn't fall off when filling or you will be swimming in oil. Ask me how I know! DOH!
This job should take about an hour per axle.
Old Oct 2, 2009 | 09:20 PM
bansh-eman's Avatar
MikeyB helped me do the brake fluid and my gear oil today. Dude has some niffty gadgets to get the job done! Thanks again Mike!!!
Old Oct 3, 2009 | 06:50 AM
MikeyB's Avatar
No problem Greg. Glad I could help. And thanks for the beer!
MikeyB
apache1010
Mar 19, 2008 09:49 AM
1919a4-a6
Jul 29, 2007 11:08 PM
walkram42
Mar 29, 2007 09:51 AM
97catintenn
Apr 8, 2004 05:28 PM
accordionjohn
Oct 7, 2002 12:54 PM
