Cat removal, any benefits ?
2004.5 - Federal emission truck, 110K, w/auto. Considering removing the cat convertor. I live in california, so i have to pass emissions test every couple years. Main reason for removal would be for longevity of the cat. I don't mind putting it back in every two year for smog testing.
I just don't want to have to pay to replace it if it ever fails. Figure by not running it, it should last me a lifetime.
Thoughts on this ? and are there any other benefits to removing it ?
You might pick up a little hp and .5 mpg, but nothing serious.
Not ever needing it, I am not knowledgeable on the subject... look in your warranty book and see what the warranty on emissions equipment is, for some reason or another I thought it was lifetime.
Definitely NOT lifetime. I work for a repair shop, and we do smog tests. Emission equipment does have a longer warranty period, especially here in CA. Usually it's all over by 100K.
I'd buy a spare cat if i could find one reasonable.
Thanks for the input though. I'll be happy if there aren't cons to the idea. Which i know there aren't, but a few pro's are never bad either.
I live in Texas and no emission testing thank god. I removed mine cause it split wide open and can't afford a new one as they cost well over $600 alone. Not including labor. I tried looking for one (like from here and other places like here) and I could get one but then nobody would even touch my truck unless I bought it from them personally at their shop. Only place I could get one was the dealership cause nobody worked with my standard 4" pipe. Good luck.
You won't gain anything except maybe a little less time to cooldown at idle. The cat is a very high flow unit, and is only robbing 2-4 rwhp at most.
They are a PITA to remove, so it's not worth it for what you are talking about.
If it is not causing any issues just leave it. You will not notice any change.
I know If I had to have one for emissions tests, I sure would want mine to last as long as possable,,maybe run with the replacement pipe and have a muffler shop modify the cat for easy change out,,sounds like a good Idea to me.
