Carrier bearing spacers
Old May 28, 2007 | 07:26 AM
snakefarmer's Avatar
I am getting driveline shudder when pulling my fifth wheel. From what I have read in these forums it is most likely the carrier bearing needing to be shimmed. there are six different sizes available ranging from 14 to 133 mm, I m not sure which size to use any help would be appreciated.
Old May 28, 2007 | 07:45 AM
Hounddog's Avatar
Their is a TSB on this and the instructions on how to measure with a inclination gauge.Its pretty easy.Truck needs to have trailer or load on it and 0n level ground.Tech that checked mine was under it all of two or three minutes.Mine was dead in specs with a 3 horse/8 foot living qtrs horse trailer with front generator/propane tanks,hyd.jack etc.
Old May 28, 2007 | 01:41 PM
PourinDiesel's Avatar
One or more of your U joints is shot.....
Old May 28, 2007 | 05:13 PM
Hounddog's Avatar
Not always.I was told over and over a shot u/joint on a hot shudder on take off.U/joints were like new when pulled apart.Mine I think was in the liminted slip in the differantial.Have not pulled heavy enough far enough to check if repaired but I ruined three like new u/joints hunting my shudder.
Old May 28, 2007 | 05:16 PM
I put a spacer in and 2 months later I was replacing U joints...22k miles on the clock has 2 BURNT UP joints...
To each his own...
6 speed + 50K miles + 03 and up=NEED U JOINTS!!
Old May 28, 2007 | 05:59 PM
JohnnyH's Avatar
Not necessarily, I now have a slight shudder unloaded that only started after replacing the factory joints with Precisions. My vibration is gone, but now I have this.
Old May 28, 2007 | 11:36 PM
nriver's Avatar
http://dodgeram.info/tsb/2004/03-003-04.htm
linky
Old May 29, 2007 | 11:10 AM
dodgezilla04's Avatar
my center u joint was completely gone at 28k, all of a sudden it was just vibrating like crazy. it was still tight, but hot as heck to the touch. i think chris may be right. even if it isnt completely joints, at least you can replace them with greaseables and be done with it.
ajb1974
Mar 18, 2015 05:49 PM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
DodgeGirl
Sep 20, 2003 03:06 AM
Stroke This 24V
Jul 3, 2003 02:40 AM
rich
0
Oct 4, 2002 06:18 PM
