Can't shift into neutral or 4lo
Can't shift transfer case into neutral or 4lo
My manually shifted transfer case behind an automatic transmission shifts fine into 4hi, but I can't get it to budge into neutral or 4WD lo while driving on a wet, muddy surface. I'm coasting along at less than 5 mph per the owners manual - any useful hints or tips appreciated.
I stop, put tranny in neutral, and use a "quick" almost slam into 4 lo. Don't stop in neutral on the T case shifter as you may have to kill the motor to keep from grinding gears getting it out. Any speed under 50 mph for 4 hi. Never had a problem.
wrangler04
Jul 26, 2007 01:58 AM
JuzPlaneKrazy
Apr 26, 2007 07:26 AM
thejoker502
May 7, 2006 11:03 PM
