can i use mobil 1 75-90 LS for differential fluid change?
Old Aug 10, 2013 | 04:51 PM
trajan3's Avatar
I happen to have a couple of quarts of Mobil 1 75w-90 LS differential fluid in the garage. I saw on another post that "LS" is not needed if I have the AAM axle. I have the AAM with a 3.73 ratio. Not sure if it is the 11.25 or something else though. Can I use this? Does it really cause any problems or should I go buy 4 new quarts of regular 75w-90 synthetic gear oil. Thanks for any replies.
Old Aug 10, 2013 | 10:35 PM
Sittingbull2's Avatar
I am pretty sure it should be synthetic. If you pull trailers alot they suggest you run 75-140 wt. synthetic. This is what I run in mine.
Old Aug 11, 2013 | 12:27 AM
Spooler's Avatar
It will cause no problems. Some people add LSD additive anyway. The say it helps stop the chatter some folks get when everything get's hot during a heavy pull.
Old Aug 11, 2013 | 09:55 PM
1-2-3's Avatar
Just a plain ole guy
In our town that is all that you can find. The guys at the counter sell it to Dodge guys all day long. Mine took 5 and a half quarts
Old Aug 11, 2013 | 10:14 PM
trajan3's Avatar
Thanks for the input. You are right 1-2-3. I checked and all the part stores around here only sell the LS type also. I bought a couple more quarts and will put it in tomorrow. I also learned from this site that I have the AAM 11.5 differential. This forum is great
Old Aug 12, 2013 | 09:17 PM
Spooler's Avatar
Don't over torque the bolts or they will break. 25 ft/lbs is all you need. Gasket is reusable.
Old Aug 12, 2013 | 10:19 PM
Fiftygrit's Avatar
That's all I use on my 06 works just fine 130k on her, I do have a maghytec cover on my rear diff so it does take more, but works great.
markm4
Jul 29, 2007 11:16 AM
gnuesse
Sep 17, 2006 06:48 PM
coobie
Nov 29, 2004 04:26 PM
eswartz
Sep 16, 2004 06:52 AM
L. D. Bryant
Mar 22, 2004 03:14 PM
