Burning old oil in fuel tank
Old Oct 30, 2004 | 12:22 AM
N.Johnson's Avatar
Re: Burning old oil in fuel tank
Originally posted by gdh11
Can anyone tell me what a good mix is? I am getting tired of throwing all of the old oil away that I have. A number of posts mention pouring it in the tank to be burned. With the price of fuel I like the idea, I am sure it will help with lubing the fuel system as well, just don't want to add too much at one time so for a 38 gallon tank how much can we put in there without looking like a locomotive and is it legal?
Hey dude go to the basement and get me a metric cresent wrench will yah! A 24 valve high pressure common rail bosch fuel system with microscopic injection nozzles is not fond of used motor oil. What in gods green earth are you thinking of ? My daddy used to burn his used oil in his first generation diesel pick=up. If anything the latest is new two stroke oil at 60-1 for the high pressure ulrta sensative coomon rail electronically controlled.
Old Oct 30, 2004 | 05:09 AM
FastZilla's Avatar
Re: Re: Burning old oil in fuel tank
Is this guy for real
There is 2 ways to make your money in this world
With your back or with your mind.
One pays more (mind - for the most part)...
One gives more satisfaction (back - for the most part)....
To each his own...
Probably just ignighted the flame thrower
Old Oct 30, 2004 | 01:20 PM
You are welcome to your opinion but the name calling is not appropriate.
Old Oct 30, 2004 | 04:29 PM
Barrett_Fodder's Avatar
wow....
ok then,
so there is the possibility of increased fuel economy by burning your old oil in combination with the fuel? Interesting. I had read somewhere about the 5% mixture which does equate to about 1.5 gal in a full tank. Anyone ACTUALLY doing this with a 3rd gen? What are your results? How many miles has this mixture been burned?
Old Oct 30, 2004 | 05:02 PM
Haulin_in_Dixie's Avatar
I am burning less than that and in a second gen.
Old Oct 30, 2004 | 07:50 PM
Dieseldude4x4's Avatar
The name calling has been edited and will not be tolerated again.
The guy is asking for some helpful information. If you can't answer him sensibly and politely, then don't answer at all.
If it happens again, the thread will be locked.
Old Oct 30, 2004 | 09:54 PM
Barrett_Fodder- Any increase in fuel economy you would see would be due to faulty math. If you don't take the oil into account, your fuel economy looks better, once you add the oil into the fuel used things go back to normal. Real world example: Put 13.6 gallons of diesel and 2 qts of oil in my truck friday. Trip odo said 215. 215/13.6=15.8 - wow! 215/14.1=15.1 - oh, back to normal.
Old Oct 31, 2004 | 12:23 AM
wanna... good way of putting it. I guess though if the oil is free (which it is as waste anyway) then if it burns with no problems or damage thats at least 3 free gallons of fuel i can stretch out over a few tanks of diesel... something to consider anyway.
Old Oct 31, 2004 | 06:19 AM
handymantim's Avatar
I have no idea if this works but I saw it in a magazine advertisement.......get used fry oil from restaurants and filter it with whatever (I think they used a cheesecloth in the ad) and then pour it in your tank. I'm not sure of the ratio they used. The ad said you can usually get the stuff for free. The only problem mentioned was the hassle factor of retrieving the oil from the restaurants at the time when the restuarant wants to discard it. I think the ad also added an additional filter system on the truck. Sounds like your CASS system (whatever that is) would suffice.
Does anyone do this? If so, got any tips?
Old Oct 31, 2004 | 07:04 AM
Geico266's Avatar
Used cooking oil is a good thing, you can get your family feed and fill up the tank at the same time. You can also add jet fuel, kerosene, gas, mineral spirits, denatured alcohol, Jim Beam, perfume, lindseed oil, deck preservative, oil based paint, anything that will burn (even sugar) will go through these engines no problems at all. After all they are CTD's. Just use chicken wire to get the big chunks out and let her rip.
Make sure you have AAA. Your are gonna need it.
Old Oct 31, 2004 | 07:05 AM
v8440's Avatar
Lot more involved that that. Used fryer oil is often used to make biodiesel, which can be poured directly into the tank. However, a couple of chemical reactions must take place before used oil becomes biodiesel. Do NOT just pour used oil into your tank, as it's NOT just a matter of filtration to get usable fuel. Some engines can be converted in some way to run straight vegetable oil. I don't know what that entails, nor do I know if the later cummins engines can be converted. All I know for sure is that you must not just put used fryer oil (or even unused) directly into your tank.
Search for biodiesel, both on this forum and on the internet. There's a ton of info out there on it.
Old Oct 31, 2004 | 09:55 AM
Good one.......................... Just don't use Ketchup, it will dye the fuel red you know...........
Old Oct 31, 2004 | 12:39 PM
I guess it depends on the instalation but I get about 30 miles more on a tank with oil in it than one without. That is full to the top of the neck.
As I said before, it either is used one of two ways. On hard pulls the engine devolops a little more power, but on light runs, it converts to better mileage.
There is no difference in smoke, and/or filter getting dirty.
