Burning old oil in fuel tank
Old Oct 29, 2004 | 10:00 AM
HdPower's Avatar
I really don't think you want to put any old oil in your fuel system what so ever, you might have gotten away with this years and years ago with the older diesels but with todays injection systems on these trucks you'd be asking for mucho problems....IMO.
Old Oct 29, 2004 | 01:01 PM
anestech*'s Avatar
Just take it to the local auto parts store, or quick lube place. By law, they are required to take it.
Old Oct 29, 2004 | 01:18 PM
DPG's Avatar
DPG
Why would you want to put something in your fuel tank that you are removing from your crankcase because it is too dirty?
I wouldn't do it.
DeWain
Old Oct 29, 2004 | 01:20 PM
Haulin_in_Dixie's Avatar
Look in the thread on used oil and fuel filters. There is a link there for a cummins article that gives the info you need. They say 5% which is about 1 1/2 gallon per 30 gallon tank.
I burn it in my 2nd gen all the time.
Old Oct 29, 2004 | 02:18 PM
bhoeffner's Avatar
This was a common pratice with old diesel engines which did not have the high pressure common rail injection system me do on these trucks. Not saying it wouldn't work just stating you might want to think of the possible problems that could happen to the fueling system.
Old Oct 29, 2004 | 02:23 PM
Common rail by itself is no big deal, all the old 2 cycle Detroits were common rail, Mack and Cummins and Cat always said the injector pump was superior on their individual feed systems. Read the Cummins release. They even have a system for doing that automatically on larger engines. They do have the answers on used oil in the fuel.
Old Oct 29, 2004 | 02:56 PM
Everything I've read from Cummins says not to burn waste oil in engines with a catalytic converter. They say it will plug the converter. Personally I doubt 1 quart per tank would harm anything, but I wouldn't suggest going with 5% waste oil in the fuel.
I'm all for burning waste oil, I dumped 2 quarts in mine this morning before I filled up.
Old Oct 29, 2004 | 02:59 PM
Blue600's Avatar
You beat me to it.
Old Oct 29, 2004 | 03:01 PM
I forgot that oops. Course I live in an area where the cat comes out before the first oil change.
Old Oct 29, 2004 | 03:04 PM
RustyJC's Avatar
Just something to consider. Look at the sulfated ash and/or the Conradson carbon levels of the waste oil you'll be burning. These are indicators of the amount of deposits that will be left behind in the combustion chamber, exhaust valves, turbo hot section, etc. when the waste oil is burned.
Rusty
