Building oil extrnded crank first start up of the day
Old May 12, 2015 | 02:17 PM
Diesel2013's Avatar
Hi i have a 03 2500 6 speen 4x4
Noticed it is building oil about half inch on stick since oil change 2500 miles ago it has a extended crank first startup of the day but fine other then that and doesnt blow any smoke runs fine still has same amount of power just curious what could cause this ?
Old May 12, 2015 | 02:26 PM
Grit Dog's Avatar
99% sure it's 1 or more injectors leaking.
Making oil only comes from fuel (if it's not coolant which would be evident by the oil colored milkshake) and hard start when cold is a classic example of injectors not building pressure as quickly as they should either due to returning too much fuel or leaking, which is likely your case.
You could do an injector kill test and isolate the bad one(s), or if you're over 100kmi on original injectors and stock filtration just bite it and get 6 new ones headed your way.
Bad news is that "new" re-man injectors are around $400 a piece. Good news is that is $800 less than a Dmax and changing them is MUCH easier.
I'll throw a plug for TC Diesel again. After an exhausting search, they had the best price for what I felt was the best injector value. Great service too.
You'll understand once you start looking. There is literally about 50 options you could go with for injectors.
Old May 12, 2015 | 04:28 PM
Diesel2013's Avatar
Wouldnt i have smoke or anything if an injector was leaking ? Or notice a misfire or anything there is no sign of a vibration or anything so i dont no how a injector cancel test would show anything?
Old May 12, 2015 | 06:24 PM
Grit Dog's Avatar
Good point. You'd think there would be smoke if it was leaking by the tips. It can leak into the head too.
Fuel only gets into the engine through the injectors/transfer tubes so if its making oil its coming from there.
Old May 12, 2015 | 06:41 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Don't Drive your truck if it is making oil...it takes surprising little fuel in the oil to destroy the motor.
Old May 12, 2015 | 06:52 PM
Diesel2013's Avatar
Do you think just retorqueing the transfer tubes could possibly fix my problem?
Old May 13, 2015 | 12:41 AM
Beer Barrel's Avatar
Send in an oil sample. That's just $25 and you'll know what you need to know ... Takes about a week and a half from when you drop it in the mailbox.
92smokin blacky
May 17, 2011 06:50 PM
CoolumConst
Oct 11, 2008 10:00 PM
bsj04
Feb 18, 2008 06:06 PM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
