Broke rear differential bolt
Old Jun 30, 2007 | 11:24 AM
Jeff in TD's Avatar
Where is the 30 ft-lb coming from?
The Dodge factory service manual.
Old Jul 1, 2007 | 12:04 AM
monnshyne's Avatar
Hmm mine has a rubber seal I've been using everytime I change the oil with 75-140 full syn. gear oil. All I ever do is take a open/box end wrench and tighten them up. Mine never has leaked yet nore have I broken a bolt off. Next time your at the parts house just pull one an grab another.
Mark
Old Jul 19, 2007 | 12:45 PM
rogerL1961's Avatar
I am getting ready to do mine
I think I will only tighten mine to 20 foot pounds and see if there are any leaks. I think I will check reverse torque when i am taking them off to see what they are currently. I know it won't be exactly the same but maybe it will give me an idea.
I think we are supposed to use the higher viscosity though...I read somewhere on here the was a bulletin of some sort about using the higher viscosity.
Old Jul 19, 2007 | 10:08 PM
Jeff in TD's Avatar
They appear to come with a pretty tough brown threadlocker, so I suspect the torque to back them out will be higher than what they were torqued to at the factory...
Old Jul 20, 2007 | 04:29 PM
timcasbolt's Avatar
Those bolts are M8X1.25 aren't they? Should be able to get them at Tractor Supply Company or possibly even Home Depot.
Old Jul 21, 2007 | 11:38 PM
Joe T's Avatar
Originally Posted by Need95-00CTD
Thats why I run RTV instead of a gasket...no matter how many bolts you have on there, as long as it cures properly its not leaking or coming off unless you want it too...My buddy actually RTV's then Clamps the cover on his F-body on when he goes racing, it saves him a few minutes in the pits if he breaks a ring gear, which is common for a 10 bolt. I didn't think RTV could set up that quick, but whatever works for him.
Sounds like the track wouldn't like that if they knew he was doing that ... But hey, yeah whatever works .
smokeum99ta
Dec 8, 2017 01:32 AM
twincam2000
Sep 1, 2008 04:47 PM
2500CTD
Aug 9, 2005 06:04 PM
Stevenc
Sep 27, 2004 06:32 PM
