Brake pads
Old Sep 7, 2011 | 02:34 AM
Jim Bolding's Avatar
Question Brake pads
53000 on my 2007.5 and during safety inspection I was told front brake pads were 1/32 and should be changed. any sugestions on what pads are best. I see all kinds offered in Diesel mag. please advise
2007.5 2500 4X4 6.7 delets and H&S XRT pro tuner love it
Old Sep 7, 2011 | 04:30 AM
papaduck's Avatar
I have read that the OE are the best way to go. Some recommend the Greenstuff.
I went with AutoZone Duralast because of cost. I can't tell any difference from the original set on the front. The Duralast also has a lifetime warranty and I plan to keep the truck for a long time.
Old Sep 7, 2011 | 10:57 AM
NJMurvin's Avatar
I got 50K out of my OEMs. So, I replaced with same.
Old Sep 7, 2011 | 12:20 PM
papaduck's Avatar
I had more than 105k on mine and they still had some left but was making a long trip through the Rockies so changed them early. Rears still have lots left.
Old Sep 7, 2011 | 12:24 PM
Move'n Up's Avatar
Ditto
Old Sep 7, 2011 | 12:58 PM
Rednax's Avatar
Went to 120k on first tires, brakes, shocks. Only "upgrade" (change from stock) was shocks (to Bilstein). The other two were replaced with identical to factory.
Old Sep 7, 2011 | 06:04 PM
.boB's Avatar
I replaced mine with Duralast premium from AutoZone. Pretty inexpensive, about $86 for front and rear sets. Lifetime warrenty. Definatly improved the braking on my truck. I'd use those pads again in a heart beat.
Old Sep 7, 2011 | 07:15 PM
Dr.Dizzle's Avatar
I currently use EBC Greenstuff pads on the front and rear of my truck. The front part# DP71650 is considered their 7000 series or supreme pad. I have part # DP61267 on the rear which is their 6000 series pad and a softer compound. I feel that these pads combined with the EBC rotors provide a vast improvement in stopping power over the OEM brakes. They are available by ordering them at Pep Boys, Summit, and online at Autoanything.
The OEM pads are very good if you do decide on OEM; however, do not purchase the Valu-line pads from the dealer. They are not the same as the pads on your truck. The Valu-line pads tend to squeal, crack and wear out in a short period of time. I had these pads on two of our company vehicles and they wore out fast. They are total rubbish. Just be aware,the true OEM pads can be difficult to locate.
Old Sep 7, 2011 | 09:51 PM
sdmark's Avatar
Ditto! I got about 60K from my OEMs, I switched to greenstuff. I am at 119K and still have considerable pad left. The rotor was also upgraded to the EBC Slotted/dimpled with pad change. Braking was GREATLY improved. Worth the money IMHO. Good luck!!
Dodgezilla
Mar 7, 2010 12:13 PM
Chip
14
Jun 21, 2009 03:59 AM
Farmout
Sep 19, 2003 10:26 PM
maarten
Apr 30, 2003 09:42 PM
tlea7
Apr 9, 2003 07:47 PM
