Bouncing Tire???? Help!!!
Old Jun 12, 2007 | 01:09 PM
blackmajik's Avatar
I have an 06 Big Horn and I have noticed that when I drive over a bump in the road at highway speeds the front drivers side wheel wants to bounce all over the place. Any suggestions are appreciated. Thanks in advance.
Old Jun 12, 2007 | 01:43 PM
MEGA COP's Avatar
Check the castor alignment. sounds very similar to what these trucks do when they get a leveling kit if not algined properly afterward. (Some call it death wobble). Does it stop or slow down when you slow down? or does it get worse as you keep driving (almost like a harmonic type vibration?) if so then it is your alignment.
Old Jun 12, 2007 | 01:54 PM
blackmajik's Avatar
It does stop eventually. The only reason I wasn't leaning toward that is cause it stays going straight or does that matter?
Old Jun 12, 2007 | 01:55 PM
Rollin' Smoke's Avatar
i think that the DW is more of the axle shifting side to side, rather than just one wheel bouncing as you stated. could be wrong!
Old Jun 12, 2007 | 02:03 PM
MEGA COP's Avatar
I will still track fairly straight, but the wheel will hop and shake violently, and you will definetly feel it in the stering wheel also. as far as the axel moving, that is just a result of the tires shaking so much. I would get your alignment checked ASAP. and have a much positive castor allowable put in the truck. It helped both of my trucks out and I have never had a problem with that since.
blackmajik's Avatar
Well I am going to take it to the dealer today to see what they say. I did the service on sunday and lubed the front tie rod ends and it seams to have gotten worse. I don't know if that would make it worse though???/
Old Jun 12, 2007 | 02:05 PM
MEGA COP's Avatar
Good luck! Hope it all works out, but that has been my experience with what you are describing any way.
Old Jun 12, 2007 | 02:06 PM
blackmajik's Avatar
Thanks a bunch. You have helped me.
Old Jun 13, 2007 | 07:50 AM
blackmajik's Avatar
I took it to the dealer last night and they said it was the ball joints and the support shock. They will be fixing it tomarrow. If it keeps up then I will check the allignment.
Old Jul 5, 2007 | 02:07 PM
high bid's Avatar
same problem here. I've tried to keep the castor correct. I was thinking it was the shock but now I'm going to check the ball joints; at 160k miles they're probably shot.
Old Jul 6, 2007 | 08:38 AM
HOBrian's Avatar
Not flaming just informing to others...
I thought the same thing. My truck had DW (bone stock)and I too thought it could only happen as a whole unit meaning the axle. I was driving not really worried about getting DW there were no bumps big enough that BOTH front tires would hit, so I thought I was in the clear until I hit one rather large bump with the rightside and sent the right front wheel into motion.
Rick 12v CTD
Sep 7, 2009 04:14 PM
chrismez
Jul 17, 2003 08:55 PM
DODGEBRIAN
May 30, 2003 10:28 PM
dsljunkie
Mar 28, 2003 12:05 PM
Evildiesel
Mar 26, 2003 08:55 PM
