Boost pressure
Old Aug 26, 2008 | 06:02 PM
cranberry's Avatar
Boost pressure
hey all
new to owning the cummins trucks. (old ford diesel guy)
How much boost do you see on your trucks? I'm looking to pick up some gauges and need to know what range. I'm not planning on twins or anything bigger than what I have.
thanks
Mike
Old Aug 26, 2008 | 06:23 PM
PoorMansCat's Avatar
most ive seen is about 33-34 psi... Ive got the Westach combo gauge
Old Aug 26, 2008 | 06:27 PM
CamperAndy's Avatar
0-60 psi is a good range to get. It will still be good if you do a little modding.
Old Aug 26, 2008 | 09:30 PM
mw05 dodge's Avatar
I am seeing 40+ pounds on an 05 winh an edge. is this normal.
Old Aug 27, 2008 | 07:39 AM
cranberry's Avatar
Thanks guys! I was planning on a 0-60 anyway. I just wanted to be sure.
Old Aug 27, 2008 | 10:53 AM
donnee's Avatar
When I did the gauges on my 05, I went with Isspro 60# boost.
Usually, at WOT, I see 32#.
Dont have anything special on the truck but went with the 60# just incase I want to add something later.
Old Aug 28, 2008 | 01:47 AM
05BLACKHAULER's Avatar
I've hit 42# at WOT on level #4 and was wondering if the Att. was correct?
Old Aug 28, 2008 | 11:59 AM
dodgezilla04's Avatar
i see 62-64 psi. depends on the day......
Old Sep 11, 2008 | 09:05 PM
MyDieselStinker's Avatar
How much is too much for a stock truck?
I'd like to put a QZ X2 on mine, but was going to go with a pyro and trans temp. Should I worry about boost?
Old Sep 12, 2008 | 07:13 AM
stroker101's Avatar
i have a 40psi guage and can hit 32-34psi with a relatively stock engine. no programmer or chip.
Old Sep 12, 2008 | 08:26 AM
D45's Avatar
D45
I was seeing 22-24 PSI on my stock truck.
I then installed an adjustable turbo elbow and can now hit 35-38 PSI.
Old Sep 12, 2008 | 09:11 AM
paroxysym's Avatar
with my smarty jr and a boost fooler i see around 35 psi... when i ran just a quad xzt i saw 42 psi. heck of alittle chip.. stock you wont see over 28psi
Old Sep 12, 2008 | 09:28 AM
D45's Avatar
D45
You are also running an additional boost fooler with the Smarty JR?
If so, why? The JR does boost fooling upto 44 PSI
Old Sep 12, 2008 | 09:40 AM
AH64ID's Avatar
Originally Posted by cranberry
hey all
thanks
Mike
Stock will run 32 max. The WG will open at 32 and depending on load will run from 28-32 there after.
Old Sep 12, 2008 | 10:08 AM
chrigu's Avatar
with stage 3 pump i have read 50 PSI with stock around 40
